vr update
Old Jul 5, 2010 | 06:04 PM
joe f350's Avatar
joe f350
vr update
i think its bad im taking it in and geting it replace but if i unpluge the s termail it charges at 12 volt no mater how much i rev it but im with my self to eather run it with a s termail pluged in for get a new vr
Old Jul 5, 2010 | 08:14 PM
swooshcmk's Avatar
swooshcmk
S terminal unplugged you're likely just reading battery voltage and not charging at all.
Old Jul 5, 2010 | 09:02 PM
joe f350's Avatar
joe f350
i tested it at the alt
Old Jul 5, 2010 | 09:05 PM
swooshcmk's Avatar
swooshcmk
The battery terminal at the alt will read battery voltage with the truck running or not running.
Old Jul 5, 2010 | 09:07 PM
joe f350's Avatar
joe f350
when the truck is off it read 10 volts
Old Jul 5, 2010 | 10:25 PM
lemonshindig's Avatar
lemonshindig
Joe, 12 volts will not charge the battery.
Electricity(Current) flows from a higher voltage to a lower voltage. The battery is right around 12V. So, in order to charge the battery, the voltage in the battery cables has to be > 12V, usually 13V-14V.
So leaving the S unplugged will not solve your problem.
Unplugging the S, if i'm not mistaken, disables the alternator.
Try a new voltage regulator.
joeypurcell
Maryland Chapter
Aug 4, 2012 12:45 PM
hairyboxnoogle
37
Dec 18, 2010 05:50 PM
sandyc
6.7L Power Stroke Diesel
19
Nov 15, 2010 02:02 PM
Jack_99V10
New York Chapter
Aug 17, 2008 04:32 PM
FordPickup460
Nov 7, 2006 05:59 PM
