Fuel pump?
Old Jul 5, 2010 | 01:14 PM
Hammerhead24's Avatar
Hammerhead24
Exclamation Fuel pump?
I have a 05 f-150 stx with the 4.6, my truck runs fine unless I hold the gas on the floor, around 4,000 rpm it starts to rough, its like the fuel is being shut off then back on and will continue to do it until I let off, then sometimes during normal driving it will start missing, backfire through the intake then die...come back an hour later it will fire up and run fine. I did get three codes with my scanner...PO191 which was the fuel rail pressure sensor...then system too lean on banks one and two...i dont remember what the code numbers was for those 2 codes but i have been told that if the truck shows these 3 codes then it is more than likely the fuel pump...has anyone else heard of this? Any input on what to do would be appreciated, Thanks
Old Jul 5, 2010 | 01:44 PM
screwy's Avatar
screwy
First thing I'd do is replace the fuel filter, could be clogged up.
Old Jul 5, 2010 | 02:09 PM
Hammerhead24
Its already been replaced, thanks
Old Jul 5, 2010 | 02:53 PM
screwy's Avatar
screwy
Next up I'd look at the fuel pump driver module, the casing on them is known to rust through allowing crud to get inside which can cause a number of fuel related issues. It's a small box mounted on a cross rail near the spare tire.
Old Jul 5, 2010 | 03:23 PM
Hammerhead24
I have already replaced that as well, guess I should have put this in the first post...I have also replaced the MAF sensor, no change with anything I have replaced...
Old Jul 5, 2010 | 04:38 PM
60DRB's Avatar
60DRB
Screwy hit the first two steps already. I had a fuel pump go that acted in a somewhat similar fashion. My experience with older EFI Ford fuel pumps is that I heard a loudish buzzing/whining from the pumps before/as they failed. One quit outright and the other would work at light loading, after I got up to cruising speed, but would act as you describe when asked for any load demand like acceleration. The issue you describe of working fine after a rest period still sounds like a filter issue possibility. The debris loosens and falls away from the element, and refills the filter folds when pressurized maybe...had that happen once in a Toyota a long time ago.
Old Jul 5, 2010 | 09:30 PM
Greg B's Avatar
Greg B
I would check the pressure and volume of the fuel pump. It sounds like that could be the culprit. Usually when you get a P0191 code, it's the driver module. But it can be a pump. I kept getting that code on the wife's Taurus. After checking things out, it was the fuel pump. But on the Taurus the driver module is part of the pump assembly.
Old Jul 6, 2010 | 06:01 PM
Hammerhead24
Alright, ill check the pressure, thanks for the input everyone.
Charlie19
Jun 24, 2015 09:53 PM
zackcj7
Jun 19, 2014 03:31 PM
dvldog13
Dec 30, 2013 07:15 AM
Evan_P
Nov 18, 2013 09:07 PM
bluoval 5.4
1978 - 1996 Big Bronco
17
Apr 8, 2007 10:01 AM
