need some help here
Old Feb 8, 2003 | 11:33 PM
optikal illushun's Avatar
optikal illushun
need some help here
this is for the people who been here a while...there was a guy who used heavy duty coils from napa on the front of his truck to level it out...does anyone remember who it was? he drove a 2wd 95 f-150 300/5speed short box dark red i think...i wanna ask him if it added much height to the front. i wanna get the front lifted about 2" (enough to level it out) and throw 33"s on eventually. gotta do it the budget way cuz ima poor high skewl student...thanx in advance
Old Feb 8, 2003 | 11:36 PM
steve83's Avatar
steve83
need some help here
2" is gonna make a big change in your alignment, but a junkyard will sell you the springs MUCH cheaper than NAPA. You'll have to hunt a while longer to get them, but you'll $ave $ome ca$h.
Old Feb 9, 2003 | 12:13 AM
optikal illushun
need some help here
grrr...i wanna fit 33"s and have some flex left for off-roadin without gettin a lift. what about spacers? im not worried about allignment cuz with Pa roads it'll be knocked all outta wack by the end of winter (might be now actually haha). potholes suck...
Old Feb 9, 2003 | 12:20 AM
steve83's Avatar
steve83
need some help here
Spacers give you a worse ride and LESS articulation. They're the WORST way to lift a truck because they can also concentrate stress and break the spring. Firestone will sell you good tires and a lifetime alignment - check into it!
Old Feb 9, 2003 | 01:59 AM
1993F150XL's Avatar
1993F150XL
need some help here
I searched the forums to try & help you out. Look in suspension, tires, & wheels in the thread "Effects of using slightly heavier rated coil springs" posted by Ford SIX. It was last updated 12-06-02. See if this is what you are looking for. I hope this helps.
Old Feb 9, 2003 | 09:59 AM
optikal illushun
need some help here
thanx man, apprecheate (sp?) it
Old Feb 9, 2003 | 10:41 AM
optikal illushun
need some help here
ya, thats what i was lookin for. i still dont know what to do with this. i might go for the HD coils but might wanna try using the leveling coils and adding a leaf to the rear to give it a little more stance...its time to check for leveling coil kits from lift manufactors and ill get back to y'all
Old Feb 9, 2003 | 10:58 AM
optikal illushun
need some help here
came up with some research and the here it is:
Skyjacker makes a lift 2"/1.5"
Rough Country makes 1.5" leveling coils-$129.00
Superlift makes 1-2" leveling coils w/ alignment bushings
now i figure around 100-150 for new front springs, so would going with just leveling coils and alignment bushings be the best bet? or should i just go with HD springs? im really confused
Old Feb 9, 2003 | 11:19 AM
dk5122's Avatar
dk5122
need some help here
This should help. I have a buddy that is buying these.
EXP-24412
$109.95
Vendor: Explorer Pro Comp
Product Line: Explorer Pro Comp Lifted Coil Springs
Material: Steel
Finish: Gray
A smoother ride.
Ford: 1982-96 F150, standard cap, 2WD/4WD, 1984-96 Bronco, 4WD, front lift coil springs
This set of Explorer Pro Comp lift springs gives you the extra ground clearance you need without sacrificing ride quality. It gives you a smooth ride and still responds great when subjected to off-road conditions. It also adds approximately 4 in. to the ride height.
Sold as a pair.
Copyright © 2002 by AUTOSALES, INC. dba Summit Racing Equipment
Old Feb 9, 2003 | 11:20 AM
cek181's Avatar
cek181
need some help here
the guy your talking about is GAMMADRIVER
id put in 2 inch superlift springs. they will ride better than stock most likely
Old Feb 9, 2003 | 11:24 AM
dk5122's Avatar
dk5122
need some help here
They claim up to 4" of exta height can't beat that for the money. Sorry it was so long it was the easiest way to explain the springs.
Good luck, Dan
Old Feb 9, 2003 | 11:44 AM
optikal illushun
need some help here
thanx, but i think 4" might be a little to much.thats a sweet deal tho. stupid question but i just got rancho RS5000s all around and if i do get the leveling coils and even an add a leaf will i need new shocks? or will these still be ok...
also from what i got outta gamma article is that almost all springs used were the same except with A/C (which i think is just a different name). and they used the HD in the supercab models. now my question is did they used any different spring in the suspension package (2 shocks up front, etc...)...
also i saw a 96 f-150 at a parking lot and when i pulled up next to it, his front end seemed about 2" taller than mine in the front, was thier a special package beside the suspension package that offered a higher front?
ok now that i confused y'all, the main reason for wanting to do this is i want to run 33x10.50x15 or 33x12.50x15 cuz i seen where u just level the front out and they'll fit without any major problems. thanx
Old Feb 9, 2003 | 08:19 PM
cek181's Avatar
cek181
need some help here
just a personal opinion, but 33x10.50s and 33x12.50s will look better and fit better with a 4 inch lift. 2 inches they might fit, the 10.50s will definitely fit, but they will be stuffed under there. 32x11.50s with 2 inch coils looks sweet too. i saw a truck like that yesterday in the parking lot it was real pretty. lots of options
Old Feb 9, 2003 | 10:21 PM
optikal illushun
need some help here
wow more Pa people on this board than i thought. ya, id love a 4" lift but im poor and broke and the price is a little to much, especially when i have no income...workin on resolvin the but no answers...
