Upfitter switches on the 2011
From the 2011 Owners Guide:
They are coded as follows:
Switch Circuit number Wire color Fuse
AUX 1 CAC05 Yellow 25A
AUX 2 CAC06 Green with
Brown Trace
25A
AUX 3 CAC07 Violet with
Green Trace
10A
AUX 4 CAC08 Brown 15A
More detailed information about Upfitter switches can be found at
https://www.fleet.ford.com/truckbbas/.AUX 2 CAC06 Green with
Brown Trace
25A
Green Trace
10A
I went to the fleet ford link and looked at the pic's, but do not find the Relay or the correct colored wires on my 2011 King Ranch 6.7. I did find another group of wires in that same area that are blunt cut and shrink wrapped. Is it possible that my truck has different colors, or the blunt ends are somewhere else?
Thanks
Al
Thanks
Al
Satrahan
I have the same problem with my 2011 F-350 King Ranch 6.7 Liter Diesel Crew Cab Dually. I want to hook up my Aux Diesel Pump on my external fuel tank but, I can't fine the 4 Wires for the Upfitter Switches. I see the harness with all the other wires. I looked under my dash but I can't find them. I called the Ford Dealership in Texas where I purchased my truck and they couldn't even help me!!! I looked but I guess I haven't looked good enough! Anyone have any suggestions or can you point me in the right direction. Thank You, Scott
On the king, there is an amp looking device right where your left leg would be while sitting in the truck. You can not see the wires from the faceplate removal under the steering wheel. I never found them, but got my son to get in and look around. He found them by laying upside down, and looking behind the amp looking device. That device hides them well. After he told me where it was, he had to show me again before I found them. I had my feet on the head rest and was laying on my sholders in the floorboard to find them, but they were to the left of the larger bunch of wires (left as you are sitting in the seat, right as you are upside down) just keep looking and you will find them. Or get someone small, with a flashlight to look.
Al
Al
you can't post (using their tools) if you have <25 posts.
you can't post inline (attach) if you aren't a paying member
so, all you can do is upload pictures somewhere (your profile, a gallery) or external site like photobucket.com, and then link to the pictures.
Sam
Ok.... For reference- the "v" between ur first 2 fingers at your lower knuckles on ur left hand. Rest that "v" on the lowest corner point of the amp thing, facing ur fingertip upward toward the instrument cluster. This will put your palm wrist joint resting right in front of the ebrake. Wiggle those 2 fingers around and they will be hitting the wires right in the fingerprint area of fingertips. Look for the wires comming out of the loom right where a white tag is at. Notice the speaker thingy in the pictures below for a point of reference.
For orientation, all of the below photo's were taken with an Iphone flush up against the fire wall, looking towards the drivers seat, and semi looking out the drivers door.
and.... YES..... that is a housecoat I am wearing. It was cold this morning when i took the pic's.
