'77 F100
Old Jul 4, 2010 | 03:42 PM
Alvinmac's Avatar
Alvinmac
'77 F100
I’m looking to drop a 351W in a ’77 F100. The truck is just a weekend toy that I occasional use to pull a car trailer. No racing, pulling or anything like that. So I found a 351 that’s been sitting in a garage corner for a couple of years. The guy said the car was running when the engine was pulled, but that’s been a while. Once the engine is dissamebled, I’m assuming that all required internals, valve train will come with the Cam kit. If not, what internal parts would be recommended for this set-up, and can any of the original parts be re-used? I’m trying to keep it as simple as possible, so this is what I’m looking at:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
351W Block<o></o>
351W Stock Crank<o></o>
GT 40 Heads ( I know I will have to drill the bolt holes bigger, but is any porting required?)<o></o>
Comp 35-234-3 Cam – (Is this a good choice? I’m looking for a noticeable lobe but nothing extreme.)<o></o>
Edelbrock 600cfm carb<o></o>
Old Jul 4, 2010 | 06:53 PM
460/5's Avatar
460/5
Zombie Survivalist
ok. dont know whats with all the little faces.... but, you should be fine with what you have. not sure bout the heads needin ported. should work i would think, or maybe just ported to match. internals should all be good. for comp valvetrain, you cant go wrong. HOWEVER, as popular as the their cams are, im a firm believer that crower has a better cam, hands down. its up to you, but if it was me, id get comp train, and a crower cam.
Old Jul 4, 2010 | 06:58 PM
Alvinmac's Avatar
Alvinmac
Re
Thanks for the input. Hey, those smiley faces surprised me too. Dont know what I did to make them come up.
Old Jul 4, 2010 | 07:01 PM
Alvinmac's Avatar
Alvinmac
Re
How hard will it be to match a Comp Valvetrain up with a Crower Cam. And is there any specific combo that you would recommend?
Old Jul 4, 2010 | 07:07 PM
460/5's Avatar
460/5
Zombie Survivalist
well, youd just need the correct length pushrods to go with the lifters and rockers. heres a PDF of all the cams crower offers for ford. just find the one for your motor that matches what youre wantin it to do.
http://www.crower.com/misc/m_cat.shtml
Old Jul 4, 2010 | 07:15 PM
Alvinmac's Avatar
Alvinmac
Re
Thanks for pdf
Old Jul 4, 2010 | 08:29 PM
460/5's Avatar
460/5
Zombie Survivalist
yuppers. git er done!
myakkacracka
13
Jun 16, 2016 11:33 AM
myakkacracka
Mar 17, 2014 07:35 AM
19fifty4
May 26, 2012 01:53 PM
kontoboy
Sep 12, 2010 10:58 PM
CrazyHorseUK
May 26, 2010 08:09 AM
