For the record, '97-99 V10's are all non-PI head 2-valve.
All 2000-up 2-valve V10s are PI head.
2000-2004 F-series and Excursion are 2-valve.
2005-up F-series is 3-valve, INCLUDING the F53 motorhome (class A) chassis.
2005 Excursion is 2-valve (apparently without a knock sensor).
2000-up E-series are all 2-valve, INCLUDING class C motorhomes which are built on the E-series chassis-cab.
Interesting to point out, is the 6.8L 3-valve V10s are NON-VCT engines, whereas the 5.4L 3-valve V8s ARE VCT (Variable Cam Timing) engines.
Pre-2000s 4.6/5.4/6.8L V8/V10 2-valve engines came equipped with 'teardrop' shaped intake ports on the cylinder heads, while post-2000s engines saw the introduction of rectangular shaped intake ports along with swirl inducing type combustion chambers, and hence the name 'power improved'.
