92 F-350
Old Feb 8, 2003 | 11:08 PM
67 428 Fairlane Ranchero's Avatar
92 F-350
I have a 92 F-350 cab and chasis. The truck has about 250000 mile on it and still runs strong. I have replaced the rotors(keep cracking0, callipers and pads. The problem that I have is that the spindle assy where the callipers ride have wore so bad that the drive in metal with rubber shims will not stay in, the prior owner had put some screws in the rubber to spread them out. I have been told that you can have them welded then ground down. Does anyone know the correct way of taking care of this problem. I am not sure if you can still buy them new and if you could I'm sure that they would be expensive. thanks guys
