door hinge
Old Jul 3, 2010 | 07:37 PM
AC94EXPLORER's Avatar
AC94EXPLORER
door hinge
ok so i bought complete door hinge for my 94 explorer from the junkyard. i went trying them on and i noticed on my top door hinge (the original one) has a stud on it so i have to unbolt it from the inside behind the dash. but the 94 explorer i pulled the hinge off in the junk yard has the nut on the outside instead of the inside. so my question is how the heck do i get the nut off on the inside behind the dash? more likely i have to remove the dash. but i wanted to see if someone on here has a better idea. ya i know i should of bought new pins. i figured this might be easier. well the top pick is the original hinge with the nut inside. so basicly my original hinge has a stud on it that you put a nut on the inside and the explorer from the junkyard had the stud on the body faceing out where you put the nut on the outside. both explorers are the same year. hope im makeing sense here. thanks
and this is the one from the junk yard.
65fordguy
Appearance & Dress-Up
Oct 24, 2011 11:33 PM
65fordguy
1978 - 1996 Big Bronco
Oct 20, 2011 09:35 AM
1983F1503004x4
13
Sep 5, 2011 01:06 PM
ajorn
Mar 2, 2010 01:26 PM
Casey_78
32
Jan 4, 2009 08:39 PM
