Cutting out while driving
Old Jul 3, 2010 | 12:10 PM
jwheatley20's Avatar
jwheatley20
I'm on my way back from Florida, I'm running 75 @ 1900 rpm. I felt my motor cutting out a few times. Fuel pressure stays constant at 50, egts at 900, boost at 10 psi. It's all reading normal, but it cut out like it wanted to die, then clear up just as fast as it happened. Any ideas? It hasn't done it in about 10 minutes. Hopefully it won't do it anymore.
Old Jul 3, 2010 | 01:37 PM
ljutic ss's Avatar
ljutic ss
Sounds like wire chafing, while the truck is idling gently move the wire harness around coming from the FICM going to the injectors.
Old Jul 3, 2010 | 03:08 PM
cheezit's Avatar
cheezit
pull the egr valve and look for carbon.
Old Jul 5, 2010 | 10:34 PM
jwheatley20
Sorry for the delay guys. I parked it when I got home and started around the house. I havent even actually thought about it since I got home. I'll pull the EGR tomorrow and look. If there is carbon, clean it. And that should fix it?
Also, I do the wiring harness as well.
I made it all the way home, but near about 30 miles away, it started doing it alot. I had a wrecker dialed in my phone, and my finger on send. Thats how close I thought it was to just dyin out on me.
Old Jul 5, 2010 | 11:00 PM
got2befast's Avatar
got2befast
Let me know what you come up with mine has also started doing this and I was told that might be an injector going.
Old Jul 9, 2010 | 09:07 PM
got2befast's Avatar
got2befast
Did you ever find out what is causing this?
