Sponsored by: Real Truck
Dual Front Shocks
Old Jul 3, 2010 | 10:47 AM
BIGREDFERD's Avatar
BIGREDFERD
Dual Front Shocks
Why would someone install dual front shocks? The reason I ask is I have installed new single hydraulic shocks in the front and it seems there is a lot of bounce. Not too rough, just seems once the front end gets bouncing, it takes a while to stop. The brand of shock is BDS. Just curious. Thanks.
Old Jul 3, 2010 | 12:55 PM
riggz's Avatar
riggz
If you are doing some good off roading dual shocks may be warranted. If not, then the ride will most likely be pretty stiff. Do you have coil or leaf springs? Leaf springs will be a bit more bouncy.
Old Jul 3, 2010 | 03:05 PM
samurai's Avatar
samurai
I am wondering the SAME thing. The front end on my 250 has single shock and seems to bounce a lot just even when i get into my truck.
Old Jul 3, 2010 | 06:58 PM
rickf92592's Avatar
rickf92592
Early on, shock technology wasn't what it is now and the only way we racers could get enough damping was to run multiple dampers. The Fox dampers we use on the Trophy truck are 4 1/2 inch in diameter with multiple bypasses and a huge reservoir. We also run a coil-over unit that is primarily a spring unit.
With the 2 to 2 1/2" diameter reservoir shocks on the market for production application now, the need for multiple shocks is greatly reduced.
Having said that, many of the available shocks are built to a price point and you get what you pay for.
Old Jul 3, 2010 | 07:01 PM
rickf92592's Avatar
rickf92592
Remember your tire is a (mostly) UN-DAMPED spring and large tires will have that effect somewhat.
Old Jul 4, 2010 | 08:02 AM
redford's Avatar
redford
FTE Leadership Emeritus
A very good point. Try adding or taking out 5 PSI in the front tires to see what that does to your ride.
Old Jul 5, 2010 | 05:15 PM
rickf92592's Avatar
rickf92592
A excellent demonstration is with a basketball.
Vary the inflation and compare how it bounces, your tires will (basically) do the same.
The difference with your suspension is that the more the tire is inflated, the more energy is transmitted to the suspension, including the dampers.
JRS2
Nov 28, 2015 07:22 PM
Calvin Thomas
Sep 30, 2015 05:30 AM
joshofalltrades
17
Aug 11, 2012 03:34 PM
betterleftalone
13
Aug 4, 2012 10:02 AM
Fordracer302
Jun 26, 2006 08:20 AM
