Rubber window seal
Old Jul 2, 2010 | 06:01 PM
kper05's Avatar
kper05
Rubber window seal
I'm not exactly sure of the technical name but it's the rubber seal on the front doors at the bottom of the window (outside).
Anyways, mine keep getting pushed up from normal driving although it is more frequent with bumpy two lane county roads.
I've had to push it back down several times already.
Just wondering if anyone else has noticed this.
I'll add it to the list for when I visit my dealer.
Old Jul 3, 2010 | 03:00 PM
Axemant31's Avatar
Axemant31
I had the same problem on my 05, there was also a TSB out for the problem (on the 05). It scratched up my passenger side window pretty good. Get it handled while its under warranty!
Old Jul 5, 2010 | 10:52 AM
Lovetopull's Avatar
Lovetopull
Do you have the TSB number for this? I have the same issue on all four windows of my 2006. I was going to change the truck this year, the window issue being one of the reasons. I've now got rust to contend with.
I wich they had redesigned this for the 2011!
Old Jul 16, 2010 | 06:33 PM
Axemant31's Avatar
Axemant31
Lovetopull, sorry for the delay! Here you go!
TSB 07-10-5
05/28/07
FRONT DOOR SIDE GLASS SCRATCHED DUE TO
COLLECTION OF DIRT/DEBRIS IN WARPED OUTER
WINDOW MOLDING
FORD:
2003-2007 Expedition
2005 Excursion
2005-2008 F-Super Duty
LINCOLN:
2007 Navigator
This article supersedes TSB 06-18-2 to update the vehicle model years, vehicle application and parts information.
ISSUE
Some 2005-2008 F-Super Duty, 2005 Excursion, 2003-2007 Expedition and 2007 Navigator vehicles may exhibit outer window molding weather strip assembly warping around the lower front window channel. The condition may be described as a warped or loose outer window molding. There may be a pucker or gap between the window beltline molding weather strip assembly and the window glass. This may result in dirt and debris collecting between the molding and the glass, and therefore scratching the side-window glass.
ACTION
Use the Service Procedure to replace the outer window molding and adjust the molding flange.
SERVICE PROCEDURE
1. Lower the side door window completely.
2. Remove the outside mirror.
3. Remove the outer window molding weather strip assembly by lifting it up away from the flange (Figure 1).
4. Raise the side door glass completely.
5. Measure the distance from inboard sur[ace of the door molding flange to outboard surface of the window glass (Figure 2). Distance from flange to glass should be between 5/8-3/4" (16-19 mm) for F-Super Duty and Excursion, and 3/16-7/16" (5-11 mm) for Expedition and Navigator.
6. Lower glass completely.
7. Adjust the door molding flange to meet the 5/8-3/4" (16-19 mm) dimension. Do not adjust flange more than 3/4" (19 mm) away from the glass.
8. Install a new lower window molding weather strip assembly.
9. Reinstall mirror.
10. If the side door glass has been scratched, replace the glass. Refer to Workshop Manual, Section 501-11.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
071005A 2005-2008 F-Super Duty, 0.5 Hr.
2005 Excursion: Replace
The Window Beltline
Molding Includes Time To
Measure And Adjust Door
Molding Flange One Front
Door (Do Not Use With
17628B, 17682C, 23943A,
23943B, 23943A14,
18808AF, 17682B)
071005B 2005-2008 F-Super Duty, 0.9 Hr.
The Window Beltline
Molding Flange Both Front
Doors (Do Not Use With
23943B, 23943A14,
18808AF, 17682B)
071005C 2005-2008 F-Super Duty, 0.7 Hr.
The Window Beltline
Molding Flange, And
Replace Window Glass:
One Front Door (Do Not
Use With 17628B, 17682C,
23943A, 23943B,
23943A14, 18808AF,
17682B)
071005D 2005-2008 F-Super Duty, 1.3 Hrs.
The Window Beltline
Molding Flange, And
Both Front Doors (Do Not
23943A, 23943B,
23943A14, 18808AF,
17682B)
071005E 2003-2007 Expedition, 0.6 Hr.
2007 Navigator: Replace
The Window Beltline
Molding, Includes Time To
Molding Flange: One Front
17682C, 21452A, 23943A,
23943AB, 23943A14,
18808AF, 17682B)
07100SF 2003-2007 Expedition, 1.1 Hrs.
The Window Beltline
Molding Flange: Both Front
23943AB, 23943A14,
18808AF, 17682B)
071005G 2003-2007 Expedition, 0.9 Hr.
The Window Beltline
Molding Flange And
Use With 17682C, 21452A,
23943A, 23943AB,
23943A14, 18808AF,
17682B)
071005H 2003-2007 Expedition, 1.7 Hrs.
The Window Beltline
Molding Flange And
23943A, 23943AB,
23943A14, 18808AF,
17682B)
cparks
15
Oct 6, 2013 04:03 AM
tbirdscott
Bronco II
Aug 29, 2013 05:56 AM
chris20474
Mar 10, 2012 07:49 PM
SneakyF350
Apr 13, 2008 08:32 PM
Narwhal
Jun 9, 2004 06:12 PM
