Decoding my VIN
Old Jul 2, 2010 | 02:41 AM
MCDaniels's Avatar
MCDaniels
Decoding my VIN
My Vin is F10ACM09642, I just purchased this truck and was wondering if the VIN decoding could tell me anything more about the truck? What I know is it's a 1971 F100 with a 240ci Inline 6 and 3 speed on column. Can my VIN tell me which plant it is from?
Old Jul 2, 2010 | 05:38 AM
MCDaniels's Avatar
MCDaniels
OK I have done some research and found the the F10 = F100, A = 240ci motor, C = Ontario Canada Plant, but the "M" before the numbers is throwing me. Can it mean Manual trans? The info I got was from LMC's catalog.
Old Jul 2, 2010 | 05:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Nope.
The last 6 digits of the VIN is the Numerical Sequence of Assembly, the trucks specific serial number.
F10ACM09642
F10 = F100 2WD
A = 240 1V I-6.
C = Oakville, Ontario Canada Assembly Plant
M09642 = 1971 / 1971 F100/750 serial number range: J70,001 thru M30,000.
The TRANS, AXLE and etc codes are listed on the Warranty Plate, located on the left door face below the latch.
Old Jul 3, 2010 | 03:01 AM
MCDaniels's Avatar
MCDaniels
Thank you very much for the information. I will have a look at the warranty plate today to see what it tells me.
Old Jul 4, 2010 | 01:09 AM
dlocklear11's Avatar
dlocklear11
they have an article listing all three lines and what they mean over at fordification.com as well i used it it was good but ND has this stuff locked up so just trying to help
Old Jul 4, 2010 | 05:12 PM
MCDaniels's Avatar
MCDaniels
Thanks dlocklear11 for the info. I looked into that site and they have a wealth of knowledge. Thanks for another good resource.
Old Jul 5, 2010 | 03:05 AM
NumberDummy
If you post the info here, I can decode ALL of it using the Ford truck parts catalog.
I've done this for over 700 FTE members, so there's no need to go elsewhere.
DavidSa
Oct 2, 2021 01:02 PM
Canwan
Feb 14, 2017 07:26 PM
Will237
1947 and Older Ford Trucks
Apr 4, 2016 12:35 PM
badassgixxer100
Dec 10, 2015 09:06 PM
Ross Carl
Apr 24, 2015 06:44 PM
