Trans trouble code question.
Old Jul 1, 2010 | 03:26 PM
George D.'s Avatar
George D.
I checked for codes on my trans I just put in and it flashes 5-6 then instead of repeating it fashes 9-9 then 5-6 then 9-9 WTF?
Old Jul 1, 2010 | 08:50 PM
Otahyoni's Avatar
Otahyoni
From FFI.com:
Code 56-TOT sensor output is greater than Self-Test maximum value of 4.8 volts.
Code 99-(KOEO or CM) Electronic pressure control circuit failure (E4OD). OR (KOER) EEC system hasn�t learned to control idle.
it should run through all of the codes, then repeat.
Give this a read: Ford Fuel Injection How To Run a Self-Test
Old Jul 1, 2010 | 11:41 PM
George D.'s Avatar
George D.
Ok I need to find pin out test for the ECM and harness to make sure they are good then I can take it to ford and tell them to put a new trans in.
rustyrelic
May 13, 2014 07:26 AM
Punisher56
Nov 9, 2012 11:13 PM
rustyrelic
Aug 16, 2009 05:01 PM
rustyrelic
Feb 19, 2008 05:12 PM
