Anybody used Centramatic wheel balancers???
Old Jul 1, 2010 | 02:21 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Hey guys. I've been looking at the Centramatic wheel balancers for my F-150. When i mounted my 33's on my wheels(mounted myself) i was unable to get them to balance out using just the inside bead. I cannot put weights on the outside bead of my wheels b/c they are street locks and the outside bead is rolled and too thick to put any weights on. I didn't have any stick on weights to try either. It appears that the Centramatics would balance them pretty well even though they are used tires and have seen some rocks. If anyone has used these I would like to hear what you think of them. Thanks!!
Old Jul 1, 2010 | 05:01 PM
lew52's Avatar
lew52
I have seen them back in the 80s , didn't work then , just get the stick on weights & have them balanced , If the wheel takes to much weight turn the tire 180 on the rim & see if it takes less weight....Lew
Old Jul 1, 2010 | 09:28 PM
strokin'_tatsch
I will do that. Now that school is out i can't go use the balancing machine that i usually use so i will just have to take them to someone. be my luck they just won't balance out at all. LoL
Old Jul 1, 2010 | 10:53 PM
nighthawk285's Avatar
nighthawk285
you can always try equal.....thats what I have in my tires......great stuff, I have about 6 ounces inside my 35x12.50 R16s and there's no vibration at any speed with them. We use that for a lot of people that only have one-sided wheels.
Equal Tire Balancer -- EE -- Expedition Exchange Incorporated
Balance Tires - Real Time Tire Balancing That Works
IMI - EQUAL - Tire Balancer
And you don't have to get the fancy through-the-valve-stem tool, you can just break one of the beads and pour it into the tire (just make sure you don't get any in the bead area)
Old Jul 2, 2010 | 01:09 AM
strokin'_tatsch
thats an interesting thing as well Nick. Your pretty happy with it in your 35's? i may go this route now. it says on that first website that you just drop the bag in the tire and the bag busts open after a few miles.. not sure i like that idea, but I'd be ok with pouring the stuff in there like your talking about.
Old Jul 2, 2010 | 01:32 AM
ac700wildcat's Avatar
ac700wildcat
There are a ton of class a trucks out on the road with centramatics including the one I drive everyday. They work really well unless you have a tire that is worn weird, then they just don't have enough to compensate for the imbalance. That said, there are a ton of trucks out there with equal in the tires.
Old Jul 2, 2010 | 01:51 AM
nighthawk285
I have been so far, I didn't just drop the bag in and go, I held the bag inside the tire and dumped it in. We do just throw the bag inside when we put it in the steer tires of semi-trucks
I have been very happy with it in my tires, the trick is to get the right amount in your tire and it works great. We used to use a lot of centramatics at my shop as well, but we had a problem with them wearing out....don't know how...that part was kinda before my time there.......so we've made the switch to equal.
Old Jul 2, 2010 | 02:33 AM
Dirt racer's Avatar
Dirt racer
Interesting? How does it work in cold areas? Where I live it is not unusual to get to -25F in the winter, sometimes as low as -35F, it was 32F on 30 Jun for a low in some parts of Mn a couple days ago. On cold days in the winter I notice that my tires will get low spots where it sits till you move and drive for a ways and then it will smoth out. Would this stuff make it worse or better?
Old Jul 2, 2010 | 01:33 PM
strokin'_tatsch
technically it shouldn't matter how cold it gets. I think i'm going to try this equal stuff and report back. It will probably still be a month or 2 before i have driven the truck, but i will still report back on how it does.
Old Jul 2, 2010 | 08:10 PM
nighthawk285
I don't know, it works pretty well here in Eastern Oregon. What kind of tires do you have? Even if its a very cold day, that shouldn't happen with a radial tire. If its a bias-ply, that kind of thing is normal. I used to live in Fairbanks, AK and my last winter there it was -70 below for a week.....but we never had anything like that happen with our tires.
Old Jul 3, 2010 | 01:11 AM
Dirt racer's Avatar
Dirt racer
I have noticed the flat spots on both of my trucks when its really cold. I am running radial tires on both and different brands. After I drive a block or two its fine so not that big of a deal. Maybe there is a lot of moisture in my air? I do remember the bias tires being really bad in the winter when I was a kid. Will have to try this stuff.
Old Jul 3, 2010 | 01:17 AM
gijoe4500's Avatar
gijoe4500
My tires are balanced with airsoft BBs. works great.
mmm635
6.7L Power Stroke Diesel
24
Dec 24, 2020 06:41 AM
BigSexy78
16
Dec 29, 2016 12:16 PM
74F250
Ford Truck Parts for Sale
Oct 2, 2016 04:00 PM
Tundra Pony
Texas Chapter
Mar 17, 2013 11:04 PM
ATC Crazy
Jan 18, 2011 11:15 AM
