Red Line RPM?
Old Jun 30, 2010 | 07:05 PM
a truck named effy's Avatar
a truck named effy
Red Line RPM?
Hi... just installed a new valve train, so I also installed a tachometer so I could break in the new cam at the correct RPM. Just wondering where I should put my little red shift indicator needle... and where redline would be on my engine.
Top end all new all stock, except the new cam is an RV cam.
Bottom end is all new all stock.
Thanks all
Old Jun 30, 2010 | 08:50 PM
zerfetzen's Avatar
zerfetzen
Here's a little bit of math, but keep in mind you'll probably run into valve-float before you reach the RPM derived below. The idea here is that, as a general rule of thumb, piston acceleration in feet per second per second should be kept below 100,000, and that beyond that point, the lower half is likely to come apart. But it's just a general guideline.
There's probably a better way to get at this answer, but the way I do it is to plug in my guess at a redline RPM, see what the answer is, then adjust my guess accordingly until the answer's around 100,000 piston acceleration.
Here's what you need:
RodLengthToStrokeRatio = RodLength / Stroke
Piston Acceleration = (Redline RPM)^2 * Stroke * (1+(1/(2*RodLengthToStrokeRatio)))/2189
Here's an example for my 390:
1.72 = 6.488 / 3.78
97132 = (6600)^2 * 3.78 * (1+(1/(2*1.72)))/2189
So, theoretically, I can pull 6,600 RPM and get 97,132 piston acceleration in f/s/s. Personally, I won't go above around 5,500 RPM. But that's me, and this is a "big block" or "medium block" or however people like to classify a 390.
I'm sure someone more knowledgeable about engine builds will give some good advice soon, and maybe some insight particular to your 302. I just tinker. Cheers.
Old Jun 30, 2010 | 09:55 PM
a truck named effy
1.72 = 6.488 / 3.78
Wow my high school teacher was right, I did use this after I graduated... she didn't tell me it would take 10 years.
This is what I got...
Stock 302
Stroke=3" Rod=5.09"
100,000=(x)^2*3*(1+(1/(2*(5.090/3))))/2,189
100,000=(x)^2*3*(1+(1/(2*1.696)))/2,189
100,000=(x)^2*3*(1+(1/3.392))/2,189
100,000=(x)^2*3*(1+0.2948)/2,189
100,000=(x)^2*3*1.2948/2,189
Let X=7,500
F/S/S=7,500^2*3*1.2948/2,189
F/S/S=56,250,000*3*1.2948/2,189
F/S/S=168,750,000*1.2948/2,189
F/S/S=218,497,500/2,189
F/S/S=99,816
So everything on the bottom end will fly apart at 7,600 RPM
Thanks Zerfetzen for the formula, my head hurts I am going to bed now.
Old Jun 30, 2010 | 10:42 PM
79FordBlake's Avatar
79FordBlake
Stock 302
Stroke=3" Rod=5.09"
Let X=7,500
F/S/S=99,816
I know some people turn alot more with a 302 but I keep mine under 5,500.
I thought I have heard people say the stock rods and crank will let go at 6,200? Not sure though.
Old Jul 1, 2010 | 04:11 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Interesting. I never got my 400 over 3000rpm. And the new 466 that's in it now is set at 5000rpm.
Old Jul 1, 2010 | 08:17 AM
a truck named effy
Yea, I doubt I ever get it over 5,000 under load I just wanted to know.
Any one know at what RPM max HP is with a RV cam on a stock 302?
Old Jul 1, 2010 | 07:18 PM
zerfetzen's Avatar
zerfetzen
If your RV cam was Comp Cams, they have a program you can download for free that estimates a lot of things about your engine, including peak horsepower at a given RPM.
If I remember correctly, the old 302's were great motors, but the stock rods were a weak point. If that's true, then they're not up to the task of 100,000 f/s/s. Are your rods new and aftermarket, new OEM, or reconditioned?
Old Jul 3, 2010 | 02:02 PM
a truck named effy
The cam is an Eagle Racing brand RV cam... stand by and I will go get the specs and post.
Rods are new aftermarket. They are high carbon.
Old Jul 3, 2010 | 08:19 PM
zerfetzen's Avatar
zerfetzen
It sounds like your bottom end can handle the equation then for sure. The Comp Cams free download is called Cam Quest. While it has only Comp Cams in there for you to pick, you can either pick a cam that has close specs to get an idea, or I wouldn't be surprised if you can enter your own Eagle cam specs. If you use Cam Quest, let us know what it gives you. I've done a few engine builds, and to the credit of Comp Cams, it's been pretty accurate for me, but I've never focused on the peak RPM for HP though. Cheers.
IntheTrees
Aug 4, 2009 07:19 AM
nut behind the wheel
Apr 21, 2009 06:06 PM
w-i-l-l-i-e
Sep 17, 2006 09:03 PM
Brad Brown
Dec 16, 2004 10:20 PM
flexybronc
Apr 20, 2004 09:10 AM
