Sponsored by: Auxito
2001 Supercrew running rough...
Old Jun 30, 2010 | 06:15 PM
TidePride50's Avatar
TidePride50
Hey guys. As the title says, my 2001 5.4 Supercrew started running rough today shortly before I got home. It would kinda come and go. When I pulled in the driveway and stopped before putting it into Park, you really feel it. When I shifted into Park, it felt normal. There was an obvious difference in Park and Drive. Its got about 170,000 miles on it and I have had it about a year, with no problems at all. I would appreciate any help.
Old Jun 30, 2010 | 07:26 PM
SteevenH's Avatar
SteevenH
Could be alot of things. If you're getting a bad skip it's normally a COP.
If they haven't been changed and with the mileage on your truck , that's
what I'd suspect. Especially if the CEL isn't on. Start the engine and remove each connector and listen for a change in rpm. If there is no change then that COP is your culprit. It could be alot of things but that's
where I would start. When a COP is bad the engine really stumbles under load.
Old Jun 30, 2010 | 09:11 PM
darkmage55's Avatar
darkmage55
If not that, try the plugs... with 170,000 miles and stock plugs i would suspect that, but who knows if they are the stock ones? Only you!
Old Jun 30, 2010 | 09:19 PM
TidePride50
I drove it again to feel it out and it is consistently running rough now and the service engine light came on as well. I have a good buddy that is a Ford mechanic so I'm going to take it to him tomorrow and let him check it out. He said he suspected it to be a bad coil.
Old Jul 1, 2010 | 05:43 PM
TidePride50
It turned out being the #8 C.O.P. I went through some heavy rain yesterday prior to it happening and that was the culprit. We changed it real quick and you could see the moisture on the rubber boot.
Old Jul 1, 2010 | 07:36 PM
SteevenH's Avatar
SteevenH
It's a good idea to fill those boots with a good bit of dielectric grease before installing them back on the plug. It'll help keep the water out.
~ChipsAhoy~
1997 - 2003 F150
Sep 6, 2013 11:24 AM
rkred5
1997 - 2003 F150
Aug 7, 2012 05:18 PM
bowtiebender
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 15, 2010 08:06 PM
seafox
1997 - 2003 F150
Apr 15, 2007 09:07 AM
