Hubs won't unlock...sometimes.
It is even an PITA to get them to unlock when I turn the manual lock back and forth. I usually have to do it 3-4 times while moving the axle shaft back and forth.
Odd thing is, once the right side unlocks, the driver's side unlocks no problem. But I cannot unlock the driver's side first.
Damn axle demons!
So......looks like I get to take stuff apart!!!!!!!!
What should I look for?
I think between the hubs freezing up & the vacuum operation on the hubs cutting out, (other hub problems), people are going to eventually replace them with tradional hubs like Warn.
Jake.
My truck has been in the dealer shop 4 times due to hubs not working properly.A couple times it was the vacume sulinoid not working properly(air leaks).The other times the hubs were just freezing up.You could probably take the hubs apart yourself and grease them.Then check for air leaks.Buy the way,I only have 32,000 on my truck.
[B]My hubs won't unlock when I switch off 4WD.
Are you experiencing this while your "truck" is stationary?
If so I wouldn't be too concerned.The hubs like to see a little rotation to disengage and or engage.Not much,but some.As a matter of fact it has been my experience that if I have pressure on them from being in 4wd and unlock the hubs and disengage the 4wd shift lever while sitting still it is best to roll back a foot or so to disengage everything.
Also on that note if I'm driving along in 4wd (hubs locked)and disengage the 4wd shift lever the front axle will continue to pull until it experiences some coast or deceleration.
Just my .02
If you do take it apart you must replace the o-ring !
a suggestion while your in there chk your wheel bearing for any roughness or play ,there should be none with these types of hubs (supposedly a sealed unit ) but water and dirt can enter from both sides of the hub .
Rich
Just my .02
I agree 100%. This is the same for myself reguardless of the type or year of 4x4 vehicle. Auto hubs from yesteryear were deactivated/activated in a similar fashion. Even noticable in my 99' Expi A4WD to an extent.
Jake..
I can electronically switch back to 2WD, drive around, go backwards and forward and it won't unlock until I manual move the hub lock back and forth a few times while manually turning the axle shaft.
No biggie really... I'm gonna sell it, buy a PSD 2WD Excursion with a locker here soon...
BTW, it has 77K on it.
It does not unlock not matter the circumstance. Cold - hot - rolling - not rolling etc.
Well then......probably what Forty said.
Not only going over to the Dark (smelly) SIDE,,, But 2WD!!!
The eXcursion you really want is on ebay now. You can't beat that buy it now price!
The eXcursion For MONSTA
Think Yellow ............. Dog!
Yellow! Yellow! Yellow!
well Yeti and his girls could paint it for him!!!!!!
Rich
P.S. the girls told me they want to go back to abendx,its too cold here for them ,they liked little weenie's and big trucks andwarm weather so they could were their bikini's and pink ?and that my truck is not big e nough for them !
They told me that the dog could arange this to happen real easy !
I spoke too soon, I guess. My wife and I are seriously contemplating going back to Hawaii (The Big Island) to live. I've taken all the winters that I can take. I figured it'd be cheaper to sell my X and get another over there. A 2WD diesel makes a lot of sense.
But I digress...I may just take mine after-all! I'm waiting on quotes. I kinda hope I can take it as I'd hate to start all over with the mods. But then again...
And for you FORTY!
What's up with your "Yellow" fixation? Been eatin' a little too much yellow snow!?
