EGR code 401 96 f150
Old Jun 30, 2010 | 01:15 PM
droppedf100's Avatar
droppedf100
Anyone know if this means my EGR valve is bad? Its a 96 F150 with a 302.
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
The EGR tube was replaced with a new Ford tube a few years ago and I have replaced the DPFE last year but with a used one from another truck.
Old Jun 30, 2010 | 02:34 PM
Conanski's Avatar
Conanski
The DPFE sensor is what measures airflow through the EGR tube, so check that the small lines between the DPFE and the EGR tube are intact, and then check that the EGR valve itself is operational(apply full manifold vacuum directly to it to make it open). When you do this the engine should stumble, but if it doesn't then the port between the valve and intake may be clogged with carbon.
Old Jun 30, 2010 | 04:03 PM
mprice's Avatar
mprice
Do the test conanski recommends and if the engine stumbles or dies then the valve is good. If so then you should check the vacuum line between the valve and the solenoid on the other side of the intake. I had the same P0401 and found that the vacuum reservoir had a quarter coin size hole in the underside. So much for thinking I was immune to that with the plastic one. If the line and reservoir check out then I would also test the solenoid. I can't remember if it's supply or ground controlled but I'll check in the morning if nobody else chimes in.
IIRC, fordfuelinjection.com has test procedures for the DPFE.
Al_Cuevas
1997 - 2003 F150
93
Aug 13, 2016 08:50 AM
thunderbolt427
Jan 13, 2016 09:10 PM
Staveys150
Mar 11, 2011 11:55 PM
Bert01F150
3.8 & 4.2L V6
Jun 29, 2009 10:23 PM
unclegus1369
1997 - 2003 F150
Jul 5, 2008 02:28 PM
