Sponsored by: Auxito
please help with transmission
Old Jun 30, 2010 | 08:59 AM
fordf150farmer's Avatar
fordf150farmer
Ok here is the situation that I am in. I had taken my truck to Ford for a flashing OD light and was told that I had a bad speed sensor. They then charged me 100 dollars for about a half hour worth of work, and then wanted me to pay another 200 to change the sensor. I said no and took the truck home and changed the sensor with a used one that should be good. Well, that fixed my problem for about 150 miles and I got the light back again. So then I took it to a shop where I was dropping off my cousins car and they plugged it in for free and told me that it said there was something wrong with the wiring harness, so i changed the plug (solder and shrink wrap and electrical tape) because the one in the truck had a missing tab on one side of it and didn't hook up right. this fixed my problem for about 100 miles or so. I then took the truck in for a tranny drain and filter change and had them plug it in and they gave me the code p1500 0r 1505 (cant remember which) and said it was a bad gear on the output shaft of the transfercase which they wanted about 200 bucks to do. Again I said no and did it myself (6 bucks and about 15 minutes) and I still have the light. The light doesnt come on for about 15 minutes (about how long it takes everything down there to get hot) and then it will only go away for about a minute when you turn the truck of and back on untill you let it set and get cool again. Any ideas?? im stumped at this point I want to replace the sensor, but I need the money more for gas right now so it will be awhile before i get a brand new one. Any help is greatly appriciated.
Oh the truck is a 97 4x4 with the 4.6 and electronic shift on the fly (on the dash) BW 4406 transfercase.
Old Jul 1, 2010 | 02:56 AM
Bluegrass 7's Avatar
Bluegrass 7
You need to know which code it is. No guessing. Each code deals with a totally different area.
The 1500 code is indicating an intermitant VSS circuit. IE an open, a shunt or a ground.
This can affect the transmission shifting both up and down as well as contribute to stalling.
The 1505 code involves the IAC operation as a circuit malfunction as well.
You need to buckle down and inspect these areas to make sure they are solid.
If there is some other code then I can't tell you about it right now.
Good luck..
Old Jul 1, 2010 | 04:43 PM
fordf150farmer
ok the printout that i have has two codes p0503 and p1500. it lists posible causes as conection, harness, vehicle speed sensor, and the vss drive gear. so it sounds to me like i have another bad speed sensor....
the puzzling thing is that my speedometer works fine...
HitechRedneck777
1978 - 1996 Big Bronco
Feb 21, 2013 05:49 AM
Bdefore2
31
Jul 13, 2006 08:19 PM
AmeriKen
Modular V8 (4.6L, 5.4L)
Feb 27, 2005 09:19 AM
ricket
1983 - 2012 Ranger & B-Series
Nov 14, 2003 01:34 PM
