Help! Serious 97 Aerostar woes...
The plugs say Autolite Double Platinum on the insulators. Aeroman59, I just replaced the fuel filter and the air filter is pretty clean. I also know I have the synchronizer in the correct phase with the crankshaft, I had it 180 degrees out of phase one time and it would barely even run at all. The vibration and performance is better than it was when all this started, and it park and at certain speeds the vibration is barely noticeable, so my question is, if i didn't have the crankshaft at EXACTLY TDC, but a few degrees off, would this cause the vibration and slight loss of power? I don't even think my engine has a TDC on the pulley, atleast as far as I could see.
An engine mount has not come loose or broken?
Do you have a worn driveshaft universal joint perhaps?
Rich mixture can make the engine feel lumpy.
Just a few ideas!
Aeroman.
Hi Aeroman, ok on the synchronizer. I thought it might be a motor mount cause the vibration issue showed up overnight, but the folks say it doesn't have as much power as it used to, and I know it's not u joints cause I had them replaced about 20K miles ago and you get the vibration bad if you have it in park and bring the RPMs up slightly, it has a "sweet spot" right at about 50-150 rpms above idle rpms from what I can tell where the engine shakes quite noticeably, but then kinda smooths out with slight vibration after going higher, and when you put it in drive but aren't moving the vibration becomes more noticeable too, and around 55mph you can really feel it vibrate cause it's probably hitting the spot on the RPMs. the only code I have now is a p1443, I've replaced the vacuum lines, would a bad purge canister cause this? And wouldn't running rich show a code?
rainman35
1997-2006 Expedition & Navigator
01-25-2013 11:16 AM
97fordLVR
04-28-2011 07:10 AM
tankhokie
07-08-2004 12:15 PM
