im changing the fuel filter tomorow and im also thinkin bout changing th oil im new to diesels so wats the best oil and filter for them i have a 87 f250 i dont know when the last oil change was or even tune up so im thinkin better be safe than sorry and also wat do i need for a tune up? you guys are a ton of help thanks!
The oil choices seem to be Rotella T 15w40, Dello 400 30w, Dello 400 15w40.
Filter choices seem to be Wix, Wix also makes the Napa Gold!
You can also use the larger two quart filter from the 1995 Powerstroke, I think the number is FL1995 ... Someone will verify. (Napa Gold 1734)
I myself got one of the wix filters with the valve on the bottom so you don't have to install and keep that gray plastic cap on the bottom also has the water sensor port, paid $32 at my local band autoparts and I've been running delvac 1300 15w-40 for the last 1500 miles with no complaints
Hi Everyone : I have been useing the ford motorcraft oil 15-40 the last two time I have changed my oil I like it an it seame to be doing a good job I also add lucus oil treatment everytime I change my oil . I have used rotella be for that . I am wondering whatu guys thing of the ford oil 15-40 . Thank you Rick
