Winshield Wiper Delay
Old Jun 29, 2010 | 10:36 AM
45auto's Avatar
45auto
Hey guys, got a new issue on my 2004 Edge. Wipers work, but either will not turn off, or the delay modes act erratic. Any thoughts? Thanks as always
Old Jun 30, 2010 | 06:35 AM
pawpaw's Avatar
pawpaw
Multifunction switch, or GEM problem maybe????
Corrosion on the multifunction switch internal contacts are known to cause problems & some folks have had luck taking it apart & cleaning the contacts with a good plastic safe electrical spray cleaner like CRC QD & relubing the contacts. Others have just replaced the switch. My 99 had a recall to replace it.
Any other problems wjth things that the GEM module controls???? If so, put it on your suspect list.
Some thoughts for consideration. Let us know what you find.
Old Jun 30, 2010 | 01:43 PM
45auto's Avatar
45auto
Thanks Pawpaw! not sure what it is, thought it might be some kind of semiconductor timing module? I think I could just buy something pre 1972 next time, I don't think static sensitive computers belong in automobiles! Thanks again, I'll let you know what I find.
Old Aug 19, 2010 | 12:46 PM
45auto's Avatar
45auto
hey guys, just getting back to this issue. pulled the control apart & cleaned with cramolin gold. still does the same thing. works on high & low, but runs as low in any delay position & will not turn off/park. i have to let it go to ;park position & turn off the ignition real quick to stop them. would it be the gem? or just a new switch? the thing probably does get worn eventually. TIA
Old Aug 19, 2010 | 03:30 PM
5.0B2's Avatar
5.0B2
Had to replace the run/park relay and the hi/lo relay on my 97 for that condition - they were in the pwoer distribution panel on the driver's side under the hood.
Old Aug 19, 2010 | 03:49 PM
pawpaw's Avatar
pawpaw
This is good info, as if the Hi/Lo or Run/Park relay's contacts stick, the wiper motor would want to continue to run.
Those pesky power relays are known troublesome parts.
So maybe one at a time, give those relays a thump & see if things settle down. Or maybe swap them out, one at a time, for a known good like relay & see what happens.
Old Sep 6, 2010 | 02:13 AM
PW01's Avatar
PW01
Update? I'm having similar problems with my 01
Old Sep 6, 2010 | 06:20 AM
pawpaw's Avatar
pawpaw
Is it a case of the wipers Not turning off????
rangernut09011980
Sep 20, 2015 10:12 PM
1972RedNeck
20
Aug 19, 2013 08:20 PM
turnkyle
Dec 31, 2011 11:53 AM
Boss F150
Jan 10, 2010 07:08 AM
jtapal
Nov 5, 2009 08:31 PM
