part throttle mod?
Old Jun 29, 2010 | 08:01 AM
dadsgreenpsd's Avatar
dadsgreenpsd
part throttle mod?
I have the 6 speed, and when going over bumps, especially with the horse trailer on, it is hard to maintain an even throttle pressure. Has anyone ever modified the throttle to give it less response, and therefore less "jumpy"?
I got to thinking about it, and that would be very handy, not only when going over bumps, but also when backing the trailer into place. I have searched for this type of mod, but don't see much out there. I picture a switch with a bright indicator light to let me know that it is on.....
Old Jun 29, 2010 | 08:17 AM
tsmall07's Avatar
tsmall07
I just let off the throttle when going over bumps. It also helps if you plant your heel on the floor as you go over the bump.
As for backing up, just slip the clutch some. You shouldn't really be giving it any throttle until the clutch is fully released anyway (IMO). I never use any throttle when backing trailers.
Old Jun 29, 2010 | 08:28 AM
Kwikkordead's Avatar
Kwikkordead
Are you talking about the "hitching" that happens whenever a truck and trailer combo go over bumps?
Not much you can do about that, even with your foot off the throttle.
Is your horse trailer a gooseneck?
As far as backing up the trailer, I always slip it into 4wd Low.
Makes it very easy to back up, nice slow and easy. Just let out the clutch and creep backwards.
Old Jun 29, 2010 | 08:35 AM
tsmall07's Avatar
tsmall07
I've done that as well, but I've tried to avoid it when on pavement. I've always heard it's not advised to have a truck in 4x4 on pavement. Opinions?
Old Jun 29, 2010 | 08:40 AM
Kwikkordead
If you have manual front hubs like I do, that won't be an issue.
Yes the front axle will turn, but the front hubs freewheel, so you'll never bind up your driveline.
A fully functioning ESOF system will bind up so you'll want to put your hubs in manual unlock first.
I would run that way anyway if I had that and only put the hubs in Auto when the bad weather hits.
Old Jun 29, 2010 | 08:43 AM
dadsgreenpsd
Yes, the hitching. It is a bumper pull, right around 7K. Even without the trailer, it can be a little obnoxious to maneuver with throttle, especially in low range. My F150 modifies the throttle when it is in first gear, giving you about half the throttle response. That takes away a lot of the "jumpiness".
Between the driveline slop and the stiff suspension on the 250, it's hard to keep steady. I can definitely idle out the driveway, but the growling of the tranny tends to get me some funny looks...
Doesn't seem, with the drive by wire system, that it would be difficult to insert some resistance to lower the sensitivity of the pedal. However, it's been quite a while since I have done any electronics, and didn't want to fry anything. Yet.
tsmall, do you have ESOF? if so, you probably don't want to go into 4lo on pavement. I have manual hubs and transfer, so I drop it into 4lo, but don't lock in the hubs.
Old Jun 29, 2010 | 08:52 AM
Kwikkordead
Hmmm, I guess my truck is not having that problem.
Stock tune is very "maneuverable" in that the throttle response is very linear, not twitchy at all.
Turn on the tunes and then it starts to get a little jumpy and that's with a 4.88 axle.
Old Jun 29, 2010 | 08:53 AM
tsmall07's Avatar
tsmall07
I do have ESOF. I forget that some of you guys got lucky and have manual x-fer and hubs. I miss my all manual F150. I think I might swap to warn premiums if I end up keeping the truck. I had them on my F150 as well.
The only way I know of to fix trailer jerking would be to go with a goose neck. I guess you could try going with really stiff shocks in the rear or air bags.
