shift solenoid B
Old Jun 28, 2010 | 09:11 PM
joetech's Avatar
joetech
shift solenoid B
Can anyone help me identify where ss b is located in the valve body? I am 800 miles from home and have limited access to service information. Alldata doesnt seem to have all the data. Thanks
Joe
Old Jun 28, 2010 | 10:14 PM
bismic's Avatar
bismic
Hope this helps some:
The intermediate (SSPC-C), low/reverse (SSPC-E), and overdrive (SSPC-B) clutches are each controlled by a directly proportional variable force shift (VFS) solenoid. The coast (SSPC-A) and the direct clutch (SSPC-D) are each controlled by an inversely proportional VFS.
From the Tech folder (a diagram of the clutches):
http://genemohr.com/PowerStrokeDiesel/assembly.pdf
Solenoid Body Pic:
Ford Truck Enthusiasts Forums - bismic's Album: TorqShift - Picture
Wiring Diagram:
http://www.powertraincontrolsolution...TCM4119SCH.pdf
Old Jun 28, 2010 | 10:35 PM
joetech's Avatar
joetech
Do you have that v/b on the bench now? Is there a violet/yellow wire going to one of those solenoids????
Old Jun 28, 2010 | 10:37 PM
joetech's Avatar
joetech
sorry violet/orange. not yellow.
Old Jun 28, 2010 | 10:57 PM
bismic's Avatar
bismic
Sorry, the pics are old.
Here are a couple more diagrams that may help:
Legend:
http://www.thedieselgarage.com/forum...1&d=1263228212
Old Jun 29, 2010 | 07:59 PM
joetech's Avatar
joetech
I got it fixed this morning. I looked on alldata and read every bit of info for the torqueshift. I also used the parts print out from the dealer. Changed the solenoid fluid filter and external filter. Road tested and it is brand new.
Thanks for all your help.
Old Jun 30, 2010 | 07:09 AM
mh5500's Avatar
mh5500
What was it doing before you fix it?
Old Jun 30, 2010 | 07:24 PM
joetech's Avatar
joetech
I has a delayed engaugement, a flashing tow/haul light,codes po756 and p2107,banging and erratic shifts when I came off the highway, and no overdrive.
Joe
M3dragon
N. California Chapter
Oct 25, 2015 10:09 PM
coeninski
International Region
Dec 22, 2009 05:21 PM
strongarm0331
Exhaust Systems
Jun 30, 2007 05:12 AM
voltson
Jun 6, 2007 10:14 PM
