Intercooler air leak
Old Jun 28, 2010 | 06:31 PM
rzorro's Avatar
rzorro
I have blown the blue turbo to intercooler hose twice on my late build 2004 6.0. It seems replacement is required every two years. I noticed that there is a second blue hose as the intercooler continues down toward the radiator. I have also heard of an intercooler line splitting. My 6.0 produces an extraordinarily high pitched whistle under long and sustained high rpm loads. Where should I be checking for an air leak from?
Old Jun 28, 2010 | 06:47 PM
Maxium4x4's Avatar
Maxium4x4
How much boost are you seeing? The boots last longer than 2 years unless it blows off from improper installation, a split boot is common when older. The noise can come from a cracked up-pipe flex joint or a split boot.
Old Jun 28, 2010 | 07:13 PM
cheezit's Avatar
cheezit
my guess is look for a new blt, tensioner , and possibly a water pump pully
MammaJammaTX
6.7L Power Stroke Diesel
21
Sep 17, 2021 12:36 PM
Ford4Life7.3
Jan 15, 2012 07:52 AM
damicofuel
Jan 17, 2010 03:03 PM
fordtrck302
May 27, 2008 08:45 AM
mtgrzlyman
16
May 13, 2006 10:03 AM
