service engine soon light
Old Jun 28, 2010 | 10:33 AM
19stroker99's Avatar
19stroker99
I have 1999 f250 7.3 superduty i am pulling a 35 ft 5th wheel camper my problem is when I am on a hard pull my service enging light will come on for a little whil and go off when i come out of the pull what might be causing this only mods that have been made is the air filter and tranny has been rebuilt
Old Jun 28, 2010 | 11:01 AM
HKusp's Avatar
HKusp
Your signature mentions an Edge chip, you may be over-boosting the engine and the truck is setting a code and de-fueling, which would set a soft code. Does the light stay on for a few minutes then go off? . Do you have a set of gauges?But really it could be a lot of things. A little more info about your truck and what it does when the light comes on could help.
Old Jun 28, 2010 | 11:19 AM
19stroker99
i do have a edge chip and yes it stays on for a few minutes then goes off no i do not have a set of gauges i cannot tell that that the engine runs any different when it does come on
Old Jun 28, 2010 | 11:33 AM
clintbonnie's Avatar
clintbonnie
Mine does the same thing.. It is not over boost, but i think the just the hpop can't keep up the demand.. Pretty normal with a tuner or chip.. But would suggest you get gauges to watch your EGT and Boost numbers especially when towing.. and a Trans temp gauge..
Old Jun 28, 2010 | 02:39 PM
jwhitetail's Avatar
jwhitetail
Just what every one said it's because of the tuner, normal. Most all will do this, besides costume tuning.
carl2591
Jan 25, 2015 10:07 PM
agiff
Dec 2, 2012 04:52 PM
jbush1721
1997 - 2003 F150
Nov 4, 2012 12:37 PM
whiteywhip
30
Apr 14, 2008 07:38 PM
brassy
Jun 11, 2006 11:59 AM
