a/c question
Old Jun 26, 2010 | 10:28 PM
gumper 123's Avatar
gumper 123
a/c question
put new compressor, dryer, orfice tube in. My gauges are old school R12 what kind of pressure should i have on low side set at 55lbs wright now seems to be about wright any one know
Old Jun 26, 2010 | 10:32 PM
WarOzz's Avatar
WarOzz
I seem to remember something about 60 lbs when I did my R134 conversion.
Old Jun 26, 2010 | 11:23 PM
oreocreaming's Avatar
oreocreaming
basically 1 bottle of oil and 2 12oz cans should fill ya.
Old Jun 26, 2010 | 11:26 PM
oreocreaming
oh, and the pressure depends on the ambient temperature! the hotter it is outside, the more pressure it is going to show to fill. so 55lbs at 50 degrees will show as 80 at 95 degrees. the actual temp vs pressure is totally different, just giving examples. autozone has a cheap little filler, has a clocking face on it. point the arrow to the outside temp and it will show you the pressure range you need to be in.
Old Jun 27, 2010 | 04:42 AM
tjc transport's Avatar
tjc transport
i ain't rite
you don't fill an A/C system by pressure readings. you fill the system by weight.
you want to put in 3 lbs, or 48 ounces of freon.
bennyhona
Offroad & 4x4
Nov 7, 2008 08:28 AM
gerri wright
New Member Introductions
Oct 12, 2004 05:37 PM
j wright
1947 and Older Ford Trucks
Aug 18, 2004 10:41 PM
mrjdw
Jan 15, 2002 11:46 AM
