Sponsored by: Real Truck
installing clearance light
Old Jun 27, 2010 | 05:59 AM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by spinella
i used red loctite on the nuts. i'm hoping i'll never remove the lights.
You used red? Oh crud.
Loctite® Threadlocker Red 271™ is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
Old Jun 27, 2010 | 06:06 AM
TexasRebel's Avatar
TexasRebel
I used no silicone or loctite or sealant of any kind...
doing just fine. no leaks, no rattles.
Old Jun 27, 2010 | 06:34 AM
spinella's Avatar
spinella
i've been using red for years. its not as permenent s they would like you to beleive. if i did have a hard time with it then i would just break the light topside and then remove the rest from the bottom.
Old Jun 27, 2010 | 09:55 AM
skylinekw's Avatar
skylinekw
What kind of lights did you put? factory or after market
Old Jun 27, 2010 | 10:33 AM
4starcstms's Avatar
4starcstms
I added OE lights to my 04 back after new years, it was far easier than I figured it'd be..I followed the same link and it was a big help..
No Silicone for me either, and leak free, six months now
Old Jun 27, 2010 | 01:50 PM
spinella's Avatar
spinella
factory lights and harness.
BigZ97
Dec 17, 2014 07:37 AM
klashorst
Dec 27, 2011 07:01 PM
Rongold
Dec 8, 2007 09:21 PM
closetredneck
Nov 10, 2005 06:32 AM
