MAF swap, trouble code help
Old Jul 2, 2010 | 10:08 AM
  #31
Reed's Avatar
Reed
I already have a rebuilt C6 from my other van. It is a known good unit that worked great behind this 351 previously. The only catch is I will have to add a vacuum line for the C6 modulator thingy.
I do like the overdrive since this van is my road trip vehicle, but I need to save up the money to get it rebuilt. The torque of the 351 should be able to let the van cruise at 70 in OD while only turning 2000 RPM or so.
The flexplate I ordered is supposed to fit a 351 with AOD in early 80s trucks, so I think I should be OK. See THIS THREAD
Old Jul 2, 2010 | 10:50 AM
  #32
Kemicalburns's Avatar
Kemicalburns
well thats the thing. the AOD was never mated to a 351w from the factory so i dont understand how they where able to look that up.
regardless good luck.
if you can spring for about $1300 check out Monstor transmissions online. they build a great AOD, with the wide 4r70w gearset and such.
just dont go back to a stock AOD build
Old Jul 2, 2010 | 10:53 AM
  #33
Reed's Avatar
Reed
Interesting. Well, I'll measure it when it gets here.
Pocketlint
Jul 9, 2017 06:36 AM
rustyandleaking
Dec 30, 2016 01:16 PM
MemOrex
Jun 18, 2016 08:17 AM
'90-f150-302-5spd
24
Jun 1, 2016 12:51 PM
c2z4s9
Apr 2, 2016 12:21 PM
