Running lights/ trailer
Old Jun 25, 2010 | 09:16 AM
kdexter's Avatar
kdexter
I have a problem with my electrical plug on my truck..all connections work except running lights.. I've traced/probbed wires to harness connection no power on either side..stumped
Old Jun 25, 2010 | 09:34 AM
SpringerPop's Avatar
SpringerPop
That connection is powered by a relay to protect the truck's electrical system from over-loads in a trailer. The power to the relay, and to it's coil, are both protected by fuses.
If you could give us your truck's year, we might be able to come up with a wiring diagram, along with fuse numbers and locations.
Pop
Old Jun 25, 2010 | 09:55 AM
BillyBob69's Avatar
BillyBob69
What Pop said.
There is the bank of fuses under your dash, (Which I am sure you already found), but there is also a Power Junction Box, (Fancy for... another fuse panel), under the hood on the drivers side against the firewall. There are fuses in there for trailer towing too so make sure those are all good as well. Your manual should have a diagram of what is what. If you don't have the manual then I am sure someone here will post it for you.
Old Jun 25, 2010 | 10:33 AM
SpringerPop
We also have a place for you to download an Owner's Manual for yourself to print out if you don't have one in your glove box.
We need the year of truck, however.
BTW, later SuperDutys only have one fuse panel, and it's under the instrument panel. Ford deleted the under-hood one (I believe) in 2001 or 2002.
Pop
Old Jun 25, 2010 | 10:51 AM
BillyBob69's Avatar
BillyBob69
Thanks for the info Pop. I didn't know that. And here I have been looking around for an 03 with the 7.3 in it. I would of thought something was wrong when I didn't find it under the hood. HA!
Old Jun 25, 2010 | 11:55 AM
kdexter's Avatar
kdexter
Ok 02 F350 CC. SRW..If fuse/relay bad wouldnt all funtions not be working at the truck plug..I have everything except running lights for trailer.. All lights work on the truck
Old Jun 25, 2010 | 12:06 PM
BillyBob69's Avatar
BillyBob69
On mine I have seperate fuses for each function...brakes, battery charge, left turn, right turn, parking and backup. All functions are not controlled on one fuse.
Old Jun 25, 2010 | 12:30 PM
kdexter's Avatar
kdexter
What number fuse do I need to look for
Old Jun 25, 2010 | 12:48 PM
BillyBob69's Avatar
BillyBob69
My truck & manual is at home but I can check it out and post back later today.
If you have the under-hood fuse box, then it will help. But if like SpringerPop said, not there in the 02's, then hopefully someone else will respond.
Old Jun 25, 2010 | 12:52 PM
kdexter's Avatar
kdexter
I want to say that there is 1or2 relays underhood.. Main panel under dash.. I dont have a manual to tell me whats what??
Old Jun 25, 2010 | 02:09 PM
12ozd's Avatar
12ozd
Check fuse # 38.
It is seperate from the other lighting functions.
If it is blown,the turn/brake/charge etc. would still work.
Old Jun 25, 2010 | 02:18 PM
12ozd's Avatar
12ozd
Pop
Not to mix terms,there is a cjb(central junction box) under the dash
and a bjb (battery junction box) under the hood.Both have fuses.
The bjb on the later models have most of the tow fuses,relays.
Old Jun 25, 2010 | 02:36 PM
SpringerPop
kdexter,
Go here to download an Owner's Manual and print it out so you have it available. There's a whole section describing which fuse does what.
https://www.fleet.ford.com/maintenan...ls/default.asp
Pop
Old Jun 25, 2010 | 02:52 PM
BillyBob69's Avatar
BillyBob69
Thats what I meant. Sheesh! Couldn't ya read between the lines? hehe
Old Jun 26, 2010 | 10:50 AM
kdexter's Avatar
kdexter
Just want to give a Big Thanks to FTE-members on the responses on helping with my lights.. Sure enough #38 fuse was blown.. As soon as I got off work ,Checked fuse/replaced hooked up to trailer and headed to Frankfort,KY (3hrs) to get my sisters Chebbie, Long road trip.. Sorry for the late Thank you's..
