I've wrote about this before but i need to know what you Guys or Gals think.
I have a 99 F-250 SD with power stroke 7.3. On cold mornings frezzing or below doesel leaks from the injector onto the ground. Sometimes the amount is small but others a large amount is lost and always you can smell the diesel.
If anyone has any idea what might cause this please reply. I need help Ford Dealer no help.
Diesel cant leak from the injector onto the ground. If it is you have really BIG problems. The injectors are sealed in the engine. You will have to clarify where this fuel is coming from in order to help.
