my abs and swerve light stays on..someone said maybe a cracked abs rim..how can i tell which wheel has the bad and is it a really hard job to fix?? thank you its an 06 xpl eddy bauer
The "swerve" light is probably the light for the AdvanceTrac stability control. Since your Explorer has AdvanceTrac it has a 4 channel ABS system and one ABS sensor and tone ring for each wheel. Yes, the cause of the indicators coming on could be due to a cracked tone ring. It could also be a faulty sensor, a problem with the ABS hydraulic pump, the ABS module, etc. The way to tell what component has identified a fault is to use a professional diagnostic tool to pull the diagnostics from the ABS and/or stability control modules. There is also now a consumer-grade ABS diagnostic tool that can pull the diagnostic codes from the ABS computer but for a one-time use probably costs more than having the ABS codes pulled by a shop.
A bad ABS sensor is typically not an expensive or difficult fix, unless on a GM vehicle where the sensor is built in to the wheel bearing assembly. I don't think Ford has gone that route yet. A cracked tone ring though often involves removing a halfshaft and either very carefully installing a new tone ring or replacing the halfshaft with a new or rebuilt unit. If the problem is with a control module the price will also be high.
