throttle=bog
Old Jun 24, 2010 | 06:11 PM
justinyaa420's Avatar
justinyaa420
throttle=bog
so i just got this f250 cs with camper dumped the camper and did plugs and wires now when i hit the gas hard it bogs down but wont die
Old Jun 24, 2010 | 06:25 PM
Rockstone's Avatar
Rockstone
It was running fine, with no bog before you did the plugs and wires?
Old Jun 24, 2010 | 09:12 PM
justinyaa420
didn't ever hit the gas hard cruizes at low rpm okay sounds better with new plugs and wires thinking of converting to a electric ignition points might be bad
Old Jun 24, 2010 | 10:16 PM
Rockstone's Avatar
Rockstone
Do a complete tune-up before you start throwing money at it. Have you checked the timing?
Old Jun 25, 2010 | 08:10 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Since you have points, put a dwell meter on it, and watch the dwell as you rev the motor. The top distributor bushing might be bad and the dwell (and timing) are jumping all over the place.
Sounds more like a bad accelerator pump though. Take off the air cleaner, look down the throat of the carb (with the choke open) and pump the gas - see if it sprays gas down the throat or not.
Old Jun 25, 2010 | 11:39 PM
justinyaa420
well i bought a electric ignition converstion kit i get it soon
when i hold the choke open and hit the gas it squirts gas in the carb
going to do my rear main seal along with the rest of the tune up
and change out the points then i will see if it does it
i will check the timing too
thanks
Old Jun 26, 2010 | 10:14 PM
justinyaa420
so i put the pertronix conversion kit in and now it wont start wow
if the timing is off will it not start ? it was starting with the pionts in it
i got the one for a 6volt system did it all according to the instructions so im stuck and my truck wont start
Old Jun 27, 2010 | 08:42 PM
justinyaa420
so put points back in and still wont start
Old Jun 27, 2010 | 08:46 PM
justinyaa420
was runing fine before i mess with it im trying to learn these trucks
it has to be the ignition system got fuel turns over but wont start
