I have a 2000 sd 4dr drw 4x4. My auto hub is stuck in the lock postion. I need to replace one and they cost 200. Is there after market manuals that will fit my truck?
don't know about aftermarket, but mine did the samething. take it off and apart. when you get down to just the *** & rubber diaphram. soak it with some light oil. let it set. put a whench on it turn it a couple times. then more oil. this made mine work like a champ.
Remember, you will loose the "auto" feature when you convert to Warn's. You have to get out of the truck to lock and unlock. IMO, I didn't care because I knew that my hubs were locked or not without any guessing. Here's what they look like on the truck. Takes about 20 minutes to install both without having to jack up the wheels.
