still having steering problems?
Old Jun 23, 2010 | 04:55 PM
tacurt's Avatar
tacurt
So I started out first adjusting the steering gear, which helped a little. I just replaced all four ball joints and both tie rod ends. The previous owner replaced the center link about 25K ago. I picked the truck up after an alignment and it still doesnt feel right. It doesnt feel like it wants to track straight, theres a lot of play and it almost feels like its bump steering after slight wheel movements either way. With the truck parked there is play in both wheels moving 3 and 9 oclock without moving the steering wheel. I have searched every steering post I can find and I am almost out of ideas. Could my steering gear be worn or is there another part I'm missing that could be worn. BTW 00 7.3l 2wd and all parts replaced were Moog.
Old Jun 23, 2010 | 05:11 PM
cbradford's Avatar
cbradford
Sound like you need one of these:
Red-Head Steering Gears, Seattle WA - Red-Head Steering Gears Home
Old Jun 26, 2010 | 04:18 AM
tacurt's Avatar
tacurt
I dont think its the steering gear. I only replaced the outer tie rod ends and I"m thinking the inner need replacing.
Old Jun 26, 2010 | 05:49 AM
Shepherd2's Avatar
Shepherd2
Check the drag link as well. You should be able to see it go up and down when moving the wheels if it's worn. If really bad, wheel bearings can have the same effect.
mfhull
May 4, 2021 10:43 AM
bfediuk
Jul 20, 2019 10:00 PM
AMG-SM
61
Aug 14, 2017 03:00 PM
Fish_Scientist
24
Jul 20, 2017 10:57 AM
AKHunter93
21
Aug 19, 2016 01:10 AM
