Need help identifing wires
Old Jun 23, 2010 | 12:02 AM
casterbuster's Avatar
casterbuster
My sister in law owns a 2000 ford ranger flex fuel 3.0. She recently ran over something and jerked the wires completely out of the the FLEX FUEL Sensor connector so now I have the three different color wire hanging down I have found a replacement connector, but the pig tail has three black wires... the wires hanging from the harness are BLUE, BLACK and Green... I need to know which wire goes where in the connector so I can splice these back together. Could someone help me out on this?
Old Jun 23, 2010 | 07:44 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
This may help with the wire color code/connector pin location & operating voltage.
So with a multimeter & the vehicle at KOEO you could likely read the vehicles lead voltage out, to confirm the B+ 12 volts & ground lead & the other is the sensors 5 volt signal reurn to the computer.
Flex Fuel Sensor Replicator for a Ford
Let us know how it goes.
Old Jun 23, 2010 | 08:53 AM
casterbuster
I did find 5volts at the connector but none of them have 12v... anymore help I haven't found any blown fuses yet.
Old Jun 23, 2010 | 10:08 AM
pawpaw's Avatar
pawpaw
Here is some more info on the flex fuel sensor that might be helpful & in it is a link that Rockledge was hosting on a circuit schematic that might provide a clue.
https://www.ford-trucks.com/forums/7...ical-info.html
Not sure where the B+ 12 volts to the flex fuel sensor comes from, as my repair manual wiring pictorial & repair info is strangely silent on that subject.
So I don't know if it comes directly from the computers power relay, or is fed from or through the computer.
I assume the 5 vots you've measured was at the KOEO "run" position right????
If so, it seems to me the connector should have the B+ 12 volts to it also, as the computer would need B+ to generate & send the 5 volt reference to the sensor, so maybe it's fused as you suspect, but danged if I know where right now, so maybe a member that knows, will chime in & enlighten us!!!!
