Can i Make my tilt a non-tilt steering column?
Old 06-22-2010, 09:40 PM
3TreeGuy's Avatar
3TreeGuy
3TreeGuy is offline
Ive got an 83 F250 Diesel 4spd. And it has a tilt steering wheel in it. Well heard a pop behind the steering wheel and and the the steering wheel pointed to the sky. It can adjust it back down, but it will pop all the way back up. I pulled the Steering wheel off and the blinker plastic crap out and discovered the housing that holds the lock cylinder and the blinker unit had been broken where the tilt holds. Can I make this column a non-tilt column by using parts from another column? If not, i guess i can try and get the column appart and weld it back together. Oh, by the way, I pulled the snap ring off the top of the column, and nothing will come appart, wtf, is it pressed on?
Thanks in advance,
Jerry
Old 06-23-2010, 12:59 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,708 Likes on 1,381 Posts
You will need a non-tilt column to get enough parts to change it around, so the easiest thing for you is to swap the whole non-tilt column in. There are a lot of differences between the two types of columns.
GuitarJesus
05-12-2016 07:33 AM
mrwildcat2u
03-04-2012 01:37 AM
Psyclopse
1999 to 2016 Super Duty
01-31-2012 05:03 PM
bdevr
10-04-2011 06:51 PM
TexasRebel
19
09-17-2010 09:24 PM
Quick Reply: Can i Make my tilt a non-tilt steering column?
