1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What F250/F350 is Best ?
  #31
Old 06-23-2010, 07:23 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
I once read on this site that the Superduty F250 and F350 SRW was the same except for the lift blocks making the F350 taller. Dually trucks get different suspension and stronger axles.
I believe everything I read on this site so take that into account.
  #32
Old 06-23-2010, 07:26 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
Originally Posted by Victor L
One more thing, being new to this, what is an SRW setup, and what is IMO, and PSD ?
SRW - single rear wheel
DRW - dual rear wheels
IMO - in my opinion
PSD - Power Stroke Diesel
You just hit the tip of the ice. The acronyms get worse.... much worse.
  #33
Old 06-23-2010, 07:30 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
My motto for tonight is quantity over quality.
  #34
Old 06-23-2010, 07:33 PM
5.4f250sd's Avatar
5.4f250sd
5.4f250sd is offline
That is just foolish. I am done hyjacking his thread.
  #35
Old 06-23-2010, 07:41 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
We can't agree on which color is best but I bet a lot of us can agree on what is worst.
Worst ever: Brown. I mean a true poop brown.
2nd place: Any of the Dodge psychedelic colors.
3rd place: Yellow. Hardly anything is as ugly as a big faded yellow truck. Seems like most owners also add faded flat black stripes with the texture of used sand paper.
  #36
Old 06-23-2010, 07:42 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
Apparently you're very gullible too.
  #37
Old 06-23-2010, 08:13 PM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf is offline
IMO - in my opinion
Here are some more acronyms for ya...
HPOP- High Pressure Oil Pump
CC- Crew Cab
LB- Long Bed
SC- Super Cab
SB-Short Bed
F-650 Dash Mod- Installation of a lower dash from an F-650 into a 1999-2007 F-250, 350, 450, or 550.
WigWag- Flasher lights
Scorpion- The code name given to the 2011 Super Duty engines.
PITA- Chevy
  #38
Old 06-23-2010, 09:49 PM
Ace!'s Avatar
Ace!
Ace! is offline
Good to know but my gvwr is 9400lbs!!!!!!!!!! And why does a f350 ride sooooo much stiffer? I have a friend with an 04 6.0 reg cab 350 long box and it rides really rough compared to my truck!!
Because in 2005 they went with a coil spring setup up front. So, your friend's 2004 has leafs up front and will ride more "rough".
ETA: and your GVWR is higher than 8800 because the GVWR of both the F250 and F350 went up in 2005 when they changed the suspension, brakes, etc. So, pre-2005 the trucks, F250 and F350 had lower GVWR than when your truck was made.
  #39
Old 06-24-2010, 12:03 AM
redford's Avatar
redford
redford is offline
Received 1,628 Likes on 952 Posts
The main "purpose" of the truck, is to haul my Mustang to the tracks. That means over long steep mountain passes. The four wheel drive is just to be more versatile, and more bad ***.
It is good to know that the frames got stronger in 05.
I still like the sound of a Super Cab Short Bed 4x4. Can this be found in a Surer Duty?....
Yes. A Super Cab short bed is a fairly common configuration. I have an '07 SC short bed 4x4. Look in my gallery for pictures of the truck.
My truck often hauls a 28 foot enclosed car hauler (Classic Industries Dominator) usually with an early 60s Pontiac B Body (large and heavy) in it. I get by just great with a 5.4L V-8 and 3.73 gears, but I do that in the Midwest. You'll want as a minimum a 5.4L V-8 with 4.10 gears. A V-10 or a Power Stroke Diesel (PSD) with 4.10 or 4.30 gears will be even better for your towing needs. The choice between a V-10 or a PSD is the subject of great debates on this forum, especially when the subject of which tows better and which is really cheaper to operate. I won't recommend one over the other, it's your choice.
2005+ trucks have heavier frames, larger brakes, a better automatic transmission for towing and a bit more cooling capacity. 2008+ trucks have even more cooling capacity added.
  #40
Old 06-24-2010, 10:45 AM
lakewood's Avatar
lakewood
lakewood is offline
I agree, go for a 2007 supcab, sb, 6.8l v-10, or 6.0 v-8 diesel, v-10 wont get you to good of gas milage but it will get the job done, if you plan on doing alot of towing go with the 6.0.
My 05 6.0 tows 10 times better than my 01 7.3, due to all the facotrs listed above
  #41
Old 06-24-2010, 11:49 AM
Toto's Avatar
Toto
Toto is offline
If you plan on getting a diesel, for Gods sake get a Dodge Cummins, or stick with a later model Ford V10.
  #42
Old 06-24-2010, 12:12 PM
[quote=QwkTrip;9035402]I once read on this site that the Superduty F250 and F250 SRW was the same except for...[quote]
You are correct. There is virtually no difference between an F250 and an F250.
  #43
Old 06-24-2010, 04:54 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
I once read on this site that the Superduty F250 and F350 SRW was the same except for....
I don't know what you're talking about.
I hate that I can't delete a post on this site, but I love that I can make edits without a trace.
  #44
Old 06-24-2010, 07:38 PM
84deisel's Avatar
84deisel
84deisel is offline
here sometimes
Code:
dodge does not own or manufacture cummins they just put them in the vehicle and by the way why?
  #45
Old 06-24-2010, 10:46 PM
Lol, nice mad ninja skills, my friend!
Quick Reply: What F250/F350 is Best ?
