Sponsored by: Auxito
GEM module problems!!
Old Jun 22, 2010 | 05:47 PM
vwmike72's Avatar
vwmike72
Hi! I have a 2001 F-150 XLT 4x4 and my electrical system went haywire during a recent spring storm! When I started reading posts from others who had the same problem, I realized it was a bad GEM! I just had the front window resealed and was told that it was leaking from the top corner on drivers side! Now I replaced the module with a brand new one from dealer and everything seems to be back to normal except the fog lights! I also noticed that when traveling on highway at 65 MPH, the tach seems to read higher for that same speed(maybe just my imagination?)than i remember it reading by about 200 rpm's!! Can anyone tell me why everything came back to normal but the fog lamps? I also checked the mini fuse under the hood and that is fine!! Thanks! I appreciate all that can help!!
Old Jun 22, 2010 | 07:22 PM
johnM101's Avatar
johnM101
check the wiring for the fog switch or the fog light wiring going in to the fuse relay?
Are these stock fog lights?
Old Jun 23, 2010 | 01:48 PM
vwmike72's Avatar
vwmike72
These are stock foglights that came from the factory! They worked fine before the rain event, so I would think the wiring would be fine! I'm trying to avoid taking to the dealer. Is this something only the dealer can take care of?
Thanks,
Mike
Old Jun 24, 2010 | 06:45 PM
Bluegrass 7's Avatar
Bluegrass 7
When you pull the headlite switch out, does the extra lite in the switch light?
The headlites must be in the low beam position with the control lever, to light the fogs.
If not, there is a fuse and a relay to test out.
These circuits are seperate so a fault does not take everything out.
Voltmeter is your friend!
Good luck.
Old Jun 26, 2010 | 09:05 PM
vwmike72's Avatar
vwmike72
Smile Gem Module Problems!!
Good luck.
Thanks you guys John and Bluegrass, Problem solved!! I feel like a real dumb *ss! I checked the fuse in the power Distribution Box and that was fine but little did I know that there was another fuse in the fuse panel inside for the relay (5 amp) which was bad! I'm so stupid sometimes!!
Anyway thanks for your time!! It is much appreciated!!
Mike
websurfer
19
Feb 21, 2024 06:19 PM
Trav402
6.7L Power Stroke Diesel
Mar 9, 2017 01:03 AM
gjerome
1997 - 2003 F150
Nov 15, 2016 09:25 PM
pscrow86
Nov 24, 2009 08:19 AM
clay30
1997 - 2003 F150
Jan 14, 2003 09:17 AM
