What octane you running with?
Old Jan 15, 2002 | 06:13 PM
redvet's Avatar
redvet
Just curious.
I like 89 octane usually Sunoco or Citgo.
Old Jan 16, 2002 | 07:33 AM
Petrol's Avatar
Petrol
I run 87 Reg Unl (Exxon, Shell, Chevron or Texaco) with no problems at all and for that reason I don't see why I should pay the extra to run Mid or Super. I do have a 96 Dodge work truck that I recently had to switch to 89 Plus Unl with though as it was starting to knock on Reg Unl (148k on the clock)
Petrol
99 5.4
Old Jan 16, 2002 | 07:53 AM
Boxter's Avatar
Boxter
If you look in the manual for your truck, it states to use reg unleaded 87 Octane.
Boxter
Old Jan 16, 2002 | 08:24 AM
redvet's Avatar
redvet
I don't know I guess it's a pshychological thing.
I figure when buying 89 I'm getting at least 88 octane.
I've read octane ratings could be off a point or two from laying in the tank of stations or other reasons.
So maybe 87 isn't really 87.
If gas prices go way up again I'll go with 87.
Old Jan 16, 2002 | 09:19 AM
buzzard's Avatar
buzzard
87
I've tried everything from the cheapest 87 to the most expensive 93 and haven't been able to tell one iota of difference around town or on the highway. No mileage differential either.
'00 4x4 5.4L
Old Jan 16, 2002 | 10:23 AM
FTE Ken's Avatar
FTE Ken
From 87 pumps, you'll get 87 or better, not 87 or worse. The rating system is the minumum rating. Stations sometimes put the higher octanes in the lower pumps (shortage management) but not the other way around. Fines are huge and testing is random. Putting in a higher octane isn't going to do anything for the truck if it isn't tuned for it (except build up carbon). Car and Driver did dyno tests not long ago of several vehicles using higher octane and the results show a 1-4 HP increase with 93 octane on the Ford (and it was on a Mustang, not a truck). That's not enough to feel nor will it even take a 1/10th off quarter mile times. Figure that 89 is giving maybe 1HP. Basically, its throwing money away unless you advance the timing to take advantage of it.
Old Jan 16, 2002 | 03:00 PM
Petrol's Avatar
Petrol
Ken has it alright,if your motor isn't designed/tuned to take advantage of the higher octane rated fuel the net result is wasted cash pure & simple.
I've been in the petroleum industry for 18 yrs., it's fuel qaulity you want. Look for good additive pachages (detergent, etc.)Octane is simply a so called anti-knock index (detonation of fuel prior to ignition by spark) higher octane is typically required by high compression / supercharged motors.
The sorry truth is that many well intentioned owners think they are giving the best to their baby by going to unbranded cheap gas outlets to get Prem Unl at cheap prices when they could easily save $5 or more per 25 gallon fill up (my Expy has 30 gal tank) by getting Reg Unl. Money that could otherwise go toward pizza & beer.
Old Jan 16, 2002 | 03:10 PM
adelyser's Avatar
adelyser
I run 87 octane, not just because of price, but my engine runs better on it. At the high altitudes of Denver, I notice a little more hesitatation with higher octane. Higher octane should not really give more power, but actually less. The higher octane means that the burn is slower, which in turn reduces the possibility of knocking or pinging. The lower octane gives a faster burn, which results in better combustion of the gas as well as a larger exposion in the cylinder. That should mean more power, but it definitely won't be noticeable (except to your wallet!).
Maybe I am wrong on the power thing, but I agree that there is no benefit of spending the extra money to add more carbon buildup to my engine.
Old Jan 16, 2002 | 04:07 PM
redvet's Avatar
redvet
Well guys thanks.
Looks like I'll be giving 87 octane a shot.
I've never used 87 before and after reading these replies I think I should and save $$$ as a bonus.
Old Jan 16, 2002 | 08:21 PM
D Avant's Avatar
D Avant
