Radius Arm Bushing replacement
Old Jun 22, 2010 | 08:53 PM
1986FordF150I300's Avatar
1986FordF150I300
Thumbs up
Originally Posted by Grubbworm
OK Rogue, I like the idea of not having to remove the rivets to install the bushings. But, now my question is, if I remove the rivets and replace them with bolts, will I still have to make a trip to the alignment shop when I am finished?
I would, but i got a lifetime alignment plan through Brake Check here in texas for 100$
If you don't know the last time it was aligned like me and i didn't know if the previous owner had it aligned with screwed up bushings it wouldn't hurt. I know Firestone also does the life time alignment things to but its up to you. After you get done with the bushings see if any place does a free check to see how outta wack it is. If not well all i can say is i always get it aligned after i do work with the steering and advise it
Thats my .02 cents though, lets see what others say.
Old Jun 22, 2010 | 08:54 PM
Franklin2's Avatar
Franklin2
You don't have to do an alignment. That being said, all of Ford's twin-I-beam designs tend to be more picky about alignment than other designs. So always keep an eye on tire wear on these frontends. If it is really strange, then it needs an alignment, regardless if the bushings were replaced or not. I never did get an alignment when changing the bushings, and mine drove fine and tire wear was ok.
Old Jun 22, 2010 | 08:57 PM
1986FordF150I300
What if the bushing was out and it had been aligned in the past and they didn't notice the bushing was out, this is what happened to me and it ended up making it worst. After i got the bushing replaced, then i had it aligned though the caster i can't fix atm.
Old Jun 22, 2010 | 09:02 PM
Franklin2's Avatar
Franklin2
Shame on the alignment guy for doing that. I have had that happen to me before also, and that's why I try to check everything before I take it in.
Old Jun 22, 2010 | 11:08 PM
Rogue_Wulff's Avatar
Rogue_Wulff
So true about the alignment needs on a twin I-beam. Equally true, is the NEED for QUALITY shocks. Those $15 cheapies will eat tires like they're candy......
Old Jun 23, 2010 | 07:56 AM
Grubbworm's Avatar
Grubbworm
So, let me see if I’ve got this straight. If I replace the radius arm bushings in either fashion, I should not need to immediately take it to the alignment shop, unless there is an obvious problem. And if I understand this correctly, I will definitely have to do an alignment when replacing the axle pivot bushings? I do plan on doing an alignment sometime in the near future. I will have it done when I replace the axle pivot bushings, whether or not I do that myself.
And another question, when replacing the axle pivot bushings, I do not need to remove the whole axle to replace the bushings, do I?
Old Jun 23, 2010 | 12:34 PM
Franklin2's Avatar
Franklin2
If you have some way to get them out and put the new ones in when you pull the center of the axle down, you do not need to take the whole axle out.
Old Jun 24, 2010 | 08:41 AM
Grubbworm's Avatar
Grubbworm
Good, I think I will tackle those myself when I have saved enough money for an alignment and several other parts.
Meanwhile, I think I will attempt to install the Radius Arm bushings in a couple of weekends from now. Or maybe even this weekend, if I'm not doing anything else. I can't have my truck down for any lenght of time as we are doing some home remodeling at the same time.
Old Jun 25, 2010 | 07:55 AM
ID1982F150I6's Avatar
ID1982F150I6
Hopefully your radius arm bushings are easier than mine. My driver's side was a pain. The passenger side was done in less than 45 min. I don't know how it was "suppose" to be done, but I pulled the radius arm bracket off...which in the case of the drivers side, meant cutting a bolt out. I also had to cut out the bushing washer on the driver side as everything seemed to be "stuck". Might as well get all new grade 8 bolts for the radius arm brackets, and a new nut for the radius arm itself.
Old Jun 25, 2010 | 09:10 AM
smashclash's Avatar
smashclash
I took a look at my radius arm last night. The threads on the arm near the bushing looks pretty darn rusty. Rusty to the point that i hope they don't needs replacement anytime soon...
Old Jun 27, 2010 | 11:31 AM
Grubbworm's Avatar
Grubbworm
Finished replacing my radius arm bushings yesterday. It wasn't too difficult of a job. It just took me most of the day and one trip to the neighborhood AZ for the correct size socket (1-1/8" deep-well). Rogue-Wulff, I pretty much used your method except I removed the lower shock retaining bolt instead of the upper. I still had to wrestle everything around pretty good, and I had to use a come-along a couple of times. But, all in all, it left me feeling pretty confident about doing the Axle Pivot bushings myself. Oh well, maybe I'll tackle that job sometime after the 4th of July holiday. Thanks for all of the input. I will post some pictures here as soon as I get them up at this link;
My 1985 Ford F150 4x2 pictures by Grubbworm_photos - Photobucket
Old Jun 27, 2010 | 12:03 PM
Grubbworm's Avatar
Grubbworm
Here are some pictures, as promised;
Done with this one and on to the next project.
Old Jun 27, 2010 | 06:31 PM
  #28
ID1982F150I6
Wait...the undersides of these trucks are suppose to be redish brown colored...not black.
Old Jun 28, 2010 | 12:02 PM
  #29
Wyowanderer's Avatar
Wyowanderer
Too funny....
Old Jun 28, 2010 | 01:41 PM
  #30
okiepc1's Avatar
okiepc1
Mine has that lovely brown patina, shame to paint over it lol.
okiepc1
