Edelbrock Throttle Adapter??
Old Jun 22, 2010 | 11:39 AM
guin7714's Avatar
guin7714
Has anyone installed the Edelbrock 1483 throttle adapter? Can you send me a pic of it installed?
I have a 1980 Ford F-100 with a 302. Just installed a Edelbrock performer carb and am trying to install the adapter to work with my original linkage...but I am struggling badly. I have followed the instructions that were sent, but something isn't right. If you can please send pictures of yours installed it would be greatly appreciated!!!!
Thanks in advance!
Old Jun 22, 2010 | 12:40 PM
LARIAT 85's Avatar
LARIAT 85
What transmission do you have?
Old Jun 22, 2010 | 01:00 PM
guin7714's Avatar
guin7714
Yeah I guess that would help... I have the manual transmission...3 speed on the floor with overdrive.
Old Jun 22, 2010 | 01:03 PM
LARIAT 85's Avatar
LARIAT 85
Sorry, I wish I could help you, but I only have experience with the Automatic Overdrive transmission.
I am sure someone will be along soon!
Old Jun 22, 2010 | 01:55 PM
Franklin2's Avatar
Franklin2
Here are the instructions in case anyone wants to look them over.
http://www.edelbrock.com/automotive_.../1000/1483.pdf
That seems to be a kit to adapt the tranny kickdown. They say in the instructions it's not a kit to hook the gas pedal cable up.
Old Jun 22, 2010 | 02:13 PM
guin7714's Avatar
guin7714
That is the instructions that I have, thanks but that is not what I was looking for. This is NOT an automatic transmission. In fact the manual transmission does not have any connect to this at all.
Old Jun 22, 2010 | 02:17 PM
Franklin2's Avatar
Franklin2
I read the instructions, and unless I miss-read them, a automatic tranny is what this piece is for. So I guess I am saying you do not need this piece at all if you have a manual tranny correct?
Old Jun 22, 2010 | 02:34 PM
guin7714's Avatar
guin7714
I would agree with you, or I thought that was the case...but without the adapter my cable will not connect. By that I mean that the carb connections sit further in than the old carb. So when I connect my cable to the support bracket I have a big gap between the carb and the throttle cable....
What am I doing wrong? Does anyone have any pictures to show how they connected their cable to an edelbrock carb.
Old Jun 22, 2010 | 03:07 PM
Old Hickory's Avatar
Old Hickory
You might need to reposition the support bracket or go to a shorter throttle cable.
Old Jun 22, 2010 | 03:26 PM
bashby's Avatar
bashby
I've got the adapter on mine and I took some pics but can't get them to upload to my gallery. I could email them to you if you think it will help.
Old Jun 22, 2010 | 04:37 PM
Franklin2's Avatar
Franklin2
I looked it up. For a 302 I think he needs kit #1490 along with the kit he already has.
Old Jun 22, 2010 | 06:57 PM
bashby's Avatar
bashby
Thosse pics I sent were from my 351 with edelbrock intake, might not be any help
Old Jun 22, 2010 | 08:30 PM
guin7714's Avatar
guin7714
Okay guys, I have taken some pictures of what I have installed and my issues. I can't seem to post them on here but will be happy to email them to you if you are willing to look at them and help.
As seen in the photos, I have installed the adapter as edlebrock's intructions. I have even placed the kick down lever return spring bracket to the corner of the car...which can not be correct. It seems way to close and due to this I am not able to connect the return spring. So something can not be right. Do I need the return spring? My orginal carb had a spring mounted in the rear and connected to the bracket that holds the throttle cable. Do I install taht one also? One spring? Two springs?
Any and all help is extremly appreciated. I apolgoize for my ignorance, I thought this portion of the project would be easier. Again, i will be happy to email the photos if anybody doesn't mind helping!
Thanks!
Old Jun 23, 2010 | 08:33 AM
guin7714's Avatar
guin7714
I have uploaded photos to my gallery...you should be albe to see them from there. Let me know if you can't.
Old Jun 23, 2010 | 01:47 PM
bashby's Avatar
bashby
I got them in your email but cant see them in your gallery. Maybe someone else can explain how to post pics or there are probably instructions somewhere on this site.. check here: User Gallery & Picture Display Help - Ford Truck Enthusiasts Forums
