Sponsored by: Auxito
motor hesitation
Old Jun 22, 2010 | 08:09 AM
jamfu's Avatar
jamfu
motor hesitation
I have a 2000 f150 4.2v6, and the engine light came on the other day. I hooked up my scan tool and it gave me rich mixture bank 2(p0175). So, i checked the maf sensor for voltage, good ground, and running voltages. All was fine. I also got the data from the scan tool revealing the 02 sensors were working in closed loop. ie... voltage fluctuations from .3-.8 volts on bank 2. Compared them to bank 1, and yes they indicated a a rich mixture. The engine was running fine for a couple days, then yesterday after the light came back on, i went for a drive and the engine started hesitating. I drove into work this morning, and at first there was a little hickup when I first drove off. But, everything ran smooth after that, and I got to work fine. Any of you guys have any ideas or experience like this. I would like to avoid going to the dealer, but I really dont have the time to mess around with it, without knowing what to look for. I dont want to get into a wild goose chase.
Thanks
Old Jun 22, 2010 | 08:33 AM
powersmoked's Avatar
powersmoked
Thanks
I just was involved on a different thread, same site. When repairing these vehicles there is an inverse relationship between knowledge and time. your issue could be caused by many things. I would run some techron thru the tank, change the airfilter and clean the maf if you know how. if that does not work bring it to a dealer considering your time constraints.
