First Time Bed Removal Tips?
Old Jun 21, 2010 | 06:43 PM
Roger T. Pipe's Avatar
Roger T. Pipe
OK, I finally scored a nice rust-free bed from the southwest. I'm in the northeast, so there are NONE left here...believe me, I've checked! Anyway, are there any tips for bed removal? So far I've removed all 6 bed bolts, removed rear bumper and pulled the tailgate. I know the wiring for the taillights has to go but where is the junction for it where it unplugs? Also, do I just disconnect the gas tanks at the fuel door neck or??? Any other wiring other than the tailights to worry about?How many guys do you think it'll take to lift this off? I doesn't really seem too heavy~~Thanks for any tips!
Roger
Old Jun 21, 2010 | 09:11 PM
*2fords*'s Avatar
*2fords*
The wire connector is just left of center at the rear of the bed, you should have seen it when you took the bumper off.
Disconnect the fuel hose(s) on the bed itself.
It should only take 3 guys, but 4 is better.
Old Jun 22, 2010 | 02:00 PM
Roger T. Pipe
Thanks! I'll be sure to post my results!
Roger
