It should the person that had my 85 F150 4x2 before me had one in it and it handled fine. It was a 351W though so yours might be a little slower getting up to speed but it should handle it.
PRobably more weight than a 150 should carry, helper springs, air shocks... would help but the rear axle might be overloaded. Do you have any pics of the camper? Maybe someone could guesstimate the weight.
I've had several campers in my '84 with a 6 cylinder for years. It's not fast uphill, but it carries it okay. I've installed Firestone air bags and they're a big help. It sways in the wind, and it's a little tippy, but I've learned to live with it.
The engine and the tranny are not the problem. It's the soft springs and rear axle rating. They do make slide in campers for f150's, but they stop even with the tailgate, and they are lightweight with not many creature comforts inside. That being said, I have a slide in that is short, but still very heavy. It has a full kitchen and bathroom/shower with a large holding tank, and it taxes my f250.
You can beef up the springs to help it out, but the tires and the axle may not like it.
One of the full featured campers that requires the tailgate be removed(long ones) require a f250 or 350.
How would one of those work out with an F-250HD? (83 F-250 460/4x4). Have the dana 60 rear. Tires are the regular 2900# deals.
My truck doesnt have any extra springs or anythiing its all stock and it carried one of the full featured campers for about 5 years no problem.
If you want to carefully put one of these campers on a f150 and run it about a max of about a hour trip, I guess you could do it. I went for a 2000 mile trip, and when I first tested the camper before I left home, it sagged the rearend of my f250 too much. So I installed helper springs to level it back up and stiffen the ride to get rid of some of the sway. But I should have installed a sway bar. Interstates are fine, but when you get on a narrower two lane road that has dips in the pavement near the edge, it really wallows around and you have to fight it a little bit.
And I also found out the tie downs to hold it to the truck really need to go down to the frame. I had pretty beefy brackets that bolted to the stake pockets, and then used turn-buckels to tighten the camper to the truck, but about halfway through the trip I was leaving a parking lot with a dip at the entryway, and it pulled the bracket completely out of the stake pocket.
The camper I have has a queen size bed over the cab of the truck.
The camper is a "Travel Queen" made in Riverside, CA. I cannot find anything on the Internet about them so they must be gone. It has a "full" size bed over the cab and the floor is 10 ft long. It is the normal wood and sheet aluminum construction.
I will end up doing some work on it as the first foot of the floor is rotted out in the back where the door is. The PO left it sitting on the ground for many years. The end wall will also need to be worked on as the bottom is attached to the floor and will have rot. There is NO mold or mildew. The inside is very nice. No leaks in the rest of the thing. The price was right
I redid a popup camper two years ago so I have some experience in removing and rebuilding these things.
This thing is too big for a half ton truck. Travel Queens are big, and heavy. I'm not saying it can't be done; I'm saying that it isn't safe.
Frank
Here's a picture of mine. I redid it totally also from a basket case. That might be why it's a little heavier now, I used thin OSB instead of Luan for the interior walls.
Frank
I agree. These things are just too much weight for the rear axle. Even if you beef up the springs, the axle won't hold up long, and you'll have issues with brakes that don't want to stop you very well.
Thanks for the advise.
I guess I'm going to either get a bigger truck or smaller camper.
I love the truck so it's going to be a smaller camper. Maybe I'll cut this one up and make one that fits. Bare bones kind of thing.
