transmission question help
Old Jun 20, 2010 | 08:36 PM
fixitman1310's Avatar
fixitman1310
hey guys any good tranny guys here, need help and advice. i was going
on a service call, i had been on the road for about an hour and my
od light started flashing. i pulled off at an exit up to a stop light
and had no forward or reverse. i put shifter in park and then shifted
to drive, not overdrive and the truck moved. i drove it home about
70 miles with no overdrive. i get a slip code p1728. does this mean
new tranny, torque converter,etc. it has done this twice. its full of
fluid. filter is new. any help please what can i check?
thanx alot guys
steve f250 144,000 miles n.carolina 96 powerstroke e4od
p.s. is there another tranny that will work. im not pulling anything heavy.
Old Jun 21, 2010 | 06:15 PM
redman84's Avatar
redman84
Old Jun 21, 2010 | 06:38 PM
fixitman1310
Originally Posted by redman84
thanx alot redman
Old Jun 22, 2010 | 09:25 AM
redman84's Avatar
redman84
No problem bud. IIRC a P1728 is a transmission slip error-converter clutch error. From pretty much EVERYONE that has given me an educated answer it seems like a new torque converter will fix that problem but they also all suggested a rebuild while the tranny was already down to avoid it again in the future.
Old Jun 22, 2010 | 09:53 AM
MADVAN's Avatar
MADVAN
The E4 is not that smart to tell you its a tc slip.
The 4R has a better chance due to it has a input
shaft sensor. The E4 can only produce a slip code
while in OD with tc locked. It uses cps and vss to
see the slip.
Bill
Old Jun 22, 2010 | 08:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Right. The E4OD can only tell that something is slipping. It can only check when the trans is in 4th gear and the torque converter is locked.
Old Jun 22, 2010 | 10:31 PM
fixitman1310
hey guys thanx for the info. hey mark is it hard to rebuild the tranny.
i dont have 3000.00 for new tranny. i can pull the tranny myself.
i can replace torque converter, but never rebuilt one. is there any
training video's out there to help me.
thanx alot
steve
Old Jun 22, 2010 | 11:55 PM
redman84's Avatar
redman84
thanx alot
steve
I had the same thoughts myself mostly because of the cost. I had almost convinced myself to do it. Luckily I threw some red flags that stopped me. I am pretty dang mechanically inclined so I felt the same way but when guys who build engines and custom hot rods and what not told me they never tapped into an auto tranny or "only did it once", I have some serious reservations. You should be able to take your truck in and get a shop to drop, rebuild, and replace your tranny for under $3000. Much less, take it down yourself and take it in to have the benchwork done then reinstall it yourself. I was quoted at $1200 for benchwork alone if I brought it in and $2400 for the whole drop, rebuild, and install. Seems like the best way to go for a man on a budget. Though I wanted a 5 speed, found a cheap donor truck, and did the swap for a reasonable price.
Old Jun 23, 2010 | 12:13 AM
chicagodragon's Avatar
chicagodragon
in my time, i have rebuilt some C6's, C4's and 1 powergulide. the most simple trannys on the planet. but if / when my E4OD dies, iam gonna debate myself on digging into it. nowadays there are so many online tools and videos that i might try.
Old Jun 23, 2010 | 05:47 AM
Mark Kovalsky
Some people say it's hard, some say it's easy.
There is a lot of information at ATSG Home Page and even more at Service Manuals, Owner Manuals, Wiring Diagrams, Service Bulletins - Helm Incorporated.
Old Jun 23, 2010 | 07:21 AM
MADVAN's Avatar
MADVAN
http://racerxpower.com//index.php?cPath=23
bruce.o
Oct 29, 2011 12:38 PM
rbsample
Feb 3, 2011 01:04 PM
Jason Bullard
New Member Introductions
May 31, 2008 03:35 PM
