Sponsored by: Real Truck
HELP, No gauges
Old Jun 20, 2010 | 12:23 PM
rooster23's Avatar
rooster23
HELP, No gauges
I turned off the truck(F250 xl superduty,5/2003), when I restarted it I had no guages, speedo,tach etc., I have no overdrive either, everything else works,Lights in instrament cluster work, radio, all lights, even the annoying buzzer. I checked all fuses, all are good even #41,45. The wire at the shifter was chaffed, so I, stripped and re taped it. Still no gauges. Does anyone have a wiring diagram?
Any suggestion?
Thanks
Old Jun 20, 2010 | 02:24 PM
ReAX's Avatar
ReAX
Is it a 2003? 2002-04 had an HEC cluster, to enter diagnostic mode on it, hold down the reset button and turn the key on. Keep holding the button down for 2-5 seconds, then the needles will sweep. Every time you press the reset button, you will get a new feature. The odo/trip will give you some idea to what it's supposed to be doing.
Old Jun 20, 2010 | 02:27 PM
dmeyer 351 4x4 rebel's Avatar
iam in the same bout read my thread see if it helps gauge problems
