Interior Lights Come On While Driving
Old Jul 26, 2023 | 10:31 PM
  #31
John89's Avatar
John89
I recently fixed this issue. Interior and cargo lights would come on and off while driving. More so on bumpy roads. I used canned air to blow out the connector located on the left side of the cluster. I also hit it with a small shot of electrical cleaner. So far so good.
Old Aug 12, 2023 | 01:26 PM
  #32
John89's Avatar
John89
Update on issue. It is not completely fixed. It doesn't happen as often, but doesn't happen when wiggling wires at the plug so I am thinking there may be another cause. When it cools off (hopefully soon) I will give the door switches a look.
Old Aug 14, 2023 | 06:33 PM
  #33
getterdun1's Avatar
getterdun1
Based on what I've read on this forum in the past, and as previously posted here, it seems likely it's caused by a solder joint on the cluster that has a hairline crack. You could look for videos showing how to fix that. Or if you're handy with a soldering iron and have one that can heat up to say 850 degrees, you could just briefly remelt each cluster solder joint.
spuck77
Oct 25, 2024 01:41 PM
jmuenchow
24
Aug 16, 2017 03:49 PM
04F150Scab
2004 - 2008 F150
Jun 6, 2017 12:06 AM
Flargen
May 17, 2016 03:08 PM
Doubleubar
Feb 24, 2016 06:33 AM
