1940 panel
Old Jun 20, 2010 | 08:03 AM
pjhjah's Avatar
pjhjah
1940 panel
I just bought a 40 panel. My plans are, frame off, mild 8ba, t-5, 9", 4" drop axle. Do I need to split the wishbones for the t-5?, Has anyone used the Mr roadster composite rear suspension? As you can see in my avatar I just finshed a 1951. I got a lot of help from members on that forum. Any advice or links would be a big help. Thanks, Pete
Old Jul 9, 2010 | 06:25 PM
havi's Avatar
havi
I'll have the Roast Duck
AFAIK, the '40 panel, if a half ton, is the same frame as a car, so I would think a lot of the same detail pertain here when swapping a T5 in. That said, you can look here: Ford Flathead V8 .. 1932 thru 1953 • Index page There is a tech section they have that explains a bunch about the T5 behind a flathead.
pjwoolw
106
Sep 16, 2011 09:22 PM
Pete Roberts
Electrical Systems/Wiring
Apr 28, 2011 06:43 PM
pjhjah
1947 and Older Ford Trucks
Sep 19, 2010 07:38 PM
fordman1954
Jan 26, 2006 08:26 PM
