Sponsored by: Real Truck
Add A Leaf?
Old Jun 19, 2010 | 11:27 PM
ChargersFanInCO's Avatar
ChargersFanInCO
Add A Leaf?
Anybody know how much weight an add-a-leaf will allow me to carry in the bed? I've checked 3 sites and no definitive answer. I'm sure someone has added one.
Thanks
Old Jun 20, 2010 | 04:35 PM
Kajtek1's Avatar
Kajtek1
I believe they come with different ratings, so you need to check what the manufacturer says.
Even my F450 has the additional leaf -I had problems with rear sagging under load due the rear axle being up front of the center of my flatbed. (what a stupid engineer design something like it?)
So I added air helper bags. They are rated for 5000 lb. With the in-cabin controls they made me very happy
Old Jun 20, 2010 | 05:19 PM
ChargersFanInCO
Thanks...I was trying to go the least expensive route, but airbags are always an option too. I just need to carry about 600lbs more, and despise the truck not being level when I'm loaded.
Old Jun 20, 2010 | 06:10 PM
SuperDutyScaler's Avatar
SuperDutyScaler
when i had the spring shop make me a rear long add a leaf he said that a 3/8 thick spring that is twenty inches long from center pin out from either direction should carry app. 700 to 800lbs more. since i made mine as long as possible it is now third from the top it easy carries 800lbs more with a huge decrease in sag. the truck should have come this way from the factory because it doesnt ride any rougher plus it carries weight like it should not like a loaded down civic.
heres what it looks like with 4 yards of moist topsoil on my trailer
Old Jun 20, 2010 | 06:15 PM
SuperDutyScaler
also my buddy put a six inch lift on his 01 ford dually and he gave me is rear leaf springs for free. i would have put them in but they were so rusted between each leaf i just scraped them. i did us his camper leaf and bottom overload spring because they are thicker than a srw trucks springs. so they might help i dont know because i never got the truck to sag that much yet to find out.
Old Jun 20, 2010 | 07:56 PM
ChargersFanInCO
I'll go down the hill tomorrow to a place in Fort Collins and see if they have a setup I can use. I'd rather do the add-a-leaf if at all possible. Thanks.
Old Jun 22, 2010 | 04:05 PM
KansasJoe's Avatar
KansasJoe
This what you're looking for? Leaf Spring Add a Leaf 1999 - 2007 Ford F250 Super Duty
Old Jun 22, 2010 | 04:12 PM
ChargersFanInCO
Originally Posted by KansasJoe
I had to use the 08-10 ones, but yes, I'll be getting a 790lb add-a-leaf setup installed next week when they come in. Thanks!
Jacob Bush
Aug 6, 2015 02:27 PM
skibber
Sep 14, 2011 06:59 PM
Jayme Duty
36
Mar 6, 2010 01:29 AM
Ryan1265
Jun 6, 2007 09:32 PM
muddyford75
Dec 30, 2003 06:11 PM
